How hot is to hot
  • Mike whiting
    • 120
    How hot is to hot
    What temps should I be getting with the 1800 kv motor. I am running a 180 turnigy and 5 cell switched everything to 5.5 mm bullets and running a m445 prop. Runs good with 4s and 5s buy at the end of my run with the 5s one 5.5mm bullet desoders. I think I saw 118 on esc and like 130 on motor. I might have to run a m440 with the 5s. I am sure somebody can hook me up with some info
  • Mike whiting
    • 120
    Also what is the next size smaller than the m445. Going to buy a couple. I am going for the m440 is there another prop size on between
    • Diesel6401
      Memento Vivere
      • 4203
      motor is a little hot, but nothing crazy. Normally when you increase the voltage and rpm in this you should decrease the prop diameter. On 4s a m445 is fine but I would not run that size prop again on 5s, that fact that you desoldered a 5.5 with that motor is proof she is not happy with the setup. A m640 or a s215 would be good on 5s in my opinion. Decrease the diameter but still have a little pitch.
      - Diesel's Youtube
      - Diesel's Fleet
      • Mike whiting
        • 120
        What about m440. I didn't see the m640 I saw a m645. Who makes the s215.
        • Mike whiting
          • 120
          Found the s215 Prather that will fit the stock mc cable actually it's the ose cable
          • Mike whiting
            • 120
            Also with s215 the speeds is not going to be the same as the m445. Rite or wrong
            • tiqueman
              • Jul 2009
              • 5669
              Yes
              Probably a tad slower, but the electronics and connectors will be happier. But you never know, I have, on more than one occasion, found smaller props to push a boat better than a larger or same size w/ more pitch. It just depends if the motor is at its peak and being over worked or not. If its too big and it doesnt have the power to turn it, smaller props, in that case, will run faster. In your case, Im not sure though. Every set up is different.
              • Mike whiting
                • 120
                Ya ok that's what I was wondering thanks. I still haven't seen the m640. And would the m440 be a good prop to try. I am going to get a couple props with the m445 I guess being the biggest I just run 5s sometimes not all the time maybe a prop for 6s but not for sure yet but since I am going to get some props might as well get the ones I need
                • tiqueman
                  • Jul 2009
                  • 5669
                  According to my Octura prop book, they do not make a M640, which is why you cant find it. However, you can make one. Just get an X-640 and de-tongue it. M series props are just factory de-tongued x series. Its one of the simplest mods to do.
                  • Mike whiting
                    • 120
                    Ok I will do that I just need to be shown how to de tongue the prop
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      Stock motor is not rated at 6s voltage and the rpm will be to high. double dose of failure written all over that one. Like Tiq, don't under-estimate smaller props with a little pitch. Once the motor gets winding out real good the can be really fast. Bigger (prop size) isn't always better. I think the prather s215 s/b and de-tongued or the x640 s/b de-tongued would work wonders on 5s. I though about running 5s today on the stock mc with a s215 s/b/d but ran some different boats instead. the m440 can work fine, but i still bet my money on the other 2 I mentioned.
                      yea just de-tongue it. Sorry about that, i think we end up with so many modded props we end up thinking the come stock like that lol.... sorry for the confusion.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Mike whiting
                        • 120
                        Cool thanks for the info going to get those 3 props. The mc is haulin butt with the 5s with the 180. Need to get a gps. I repainted my boat now I know witch one is mine someday I'll gets some picks
                        • v-spec
                          • Jun 2009
                          • 940
                          I'd run the 42x55 grim prop or an x442 with that setup.
                          • v-spec
                            • Jun 2009
                            • 940
                            Forum lag, double post.
                            • Mike whiting
                              • 120
                              Do you de tongue the x442 also? Has anyone seen pics or a vid on how to de tongue a prop
