Prop Help for Ariane 37"
  • Luisrcboat
    • Mar 2024
    • 1
    Need help for found best prop for race namba events:
    Arianne 37"
    Motor Neu 1527 1,200kv
    Speed controller 220A Swordfish
    I use parallel two roaringtop 3,700mha 70c batteries. 6S
    Thanks
  • koen
    • Mar 2020
    • 367
    try aABC 1814-17 or the cnc lookalike from OSE then you have a good start and work your way from there
      • 4340
      That motor is on the lower end of suitable kV, but you haven't told us what voltage you're batteries are. Without that info, we cannot recommend a prop for you.
      • photohoward1
        • 1781
        6s he said. You could probably go to a bigger prop than that. It?s only a 1200kv motor. A 2115 might work. The controller is the weak spot.
          • 4340
          It was a Ninja edit...
            • 4340
            I ran an ABC 1814 on a 36" Voracity with a 1750kv motor and 6S 5000mAh. Boat ran 75mph and I only got about 2.5minutes of run time. 120A ESC was hot. The same boat ran 62mph on a stock 1600kV motor with an ABC 1915 prop, probably closer to 3-3.5min run time. With your 1200kV motor, you'll need more diameter. I agree with photohoward1, I might start with a 2114 or 2115 sized prop. By no means would my first run be a heat race. You'll need several test runs to get this sorted which watching temps and keeping track of run times or laps.
            • mappo
              • Feb 2010
              • 496
              Abc1918-10-50(2 At that Kv you can run a X52-55mm octura prop
              The Abc prop will put you at the your max temp 140F
              Do you know what the biggest problem with the world is?
              That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
