Prop too short
  • BIGGUS
    • Jun 2022
    • 4
    Prop too short
    I must be the only one not smart enough to just figure it out but I can find nothing posted here about it. I replaced the flex shaft on my ZELOS 29" with the upgraded one from OSE along with their recommended prop. Now the threads on the prop shaft don't extend far enough up towards the drive dog to allow the prop nut to seat against the prop to hold it securely. I can use a washer between the nut & prop but any that have a hole large enough for the shaft also protrude a good bit out from the body of the prop & nut and that can't be good. Any fixes or suggestions would be greatly appreciated.
  • TRUCKPULL
    • 3293
    A picture would help a lot.
    Larry
    • BIGGUS
      • Jun 2022
      • 4
      This is it. Thanks for the reply.
      • Johnc
        • Aug 2015
        • 199
        Here's what I did, used a dremel tool, ground and extended the flat of the shaft longer towards the prop end (as far as needed) installed dog and prop on the shaft, check to see if prop nut will tighten down, if not, try more extend the flattening of shaft further
        When all looks good, I take a drill bit and drill a small indent (just a bit for the grub screw to settle in and slid on the shaft) Best way to find place to make indent with drill bit is to put a bit of grease on grub nut turn it in and there ya go you have a mark.
        I'm sure other people will chime in and may have better ideas but this is what I did.
        • Peter A
          • 1622
          You can use a short piece of water line slid over the shaft and then put the nut on.
          • Johnc
            • Aug 2015
            • 199
            See no gab between dog and strut? should be gap equal to diameter of the shaft (3/16?) So move dog rearward, tighten down.
            • BIGGUS
              • Jun 2022
              • 4
              • Racingjake
                • May 2021
                • 42
                I'd go with a nylon lock nut just in case that nut comes loose ?
                • 1coopgt
                  • Feb 2019
                  • 417
                  Biggus you still need a 3/16" gap between the drive dog and the stuffing tube. The gap is for shrinkage as your speed increases. It's to keep the flex shaft from binding in the stuffing tube.
                    Exactly!
                      • 4338
                      If it were my boat...
                      Increase the gap between the dog and strut to account for flex cable shrinkage
                      Relocate the drive dog farther down the prop shaft closer to the threads. It can be glued in place with Loctite 648 to prevent it from be pushed out of adjustment by the prop and lock nut.
                      Replace washer, nut, and bullet nut with a single nyloc or Zuber lock nut
                      • bhwinsc
                        • May 2021
                        • 15
                        20220714_181050.jpgHome Depot. Everbuilt aluminum spacer is perfect. They are in the large bin area in hardware. I bought a 3/16. #10‐32 if memory serves me correctly. I took my cable with me to insure the right i.d. Also OSE sells a spacer.
                        • BIGGUS
                          • Jun 2022
                          • 4
                          Perfect. Thanks.
                          Originally posted by bhwinsc View Post
                          [ATTACH=CONFIG]175435[/ATTACH]Home Depot. Everbuilt aluminum spacer is perfect. They are in the large bin area in hardware. I bought a 3/16. #10‐32 if memory serves me correctly. I took my cable with me to insure the right i.d. Also OSE sells a spacer.
                          • Notch-R
                            • Dec 2021
                            • 17
                            ul-19, min-dom, Veles29
                            • Alfa Spirit
                              • 2183
                              Those pictures are incredible, many different washers, nuts ...
                              Prefer a drive dog like this : https://www.offshoreelectrics.com/pr...prod=ose-80248
                              Choose thick teflon washer, OSE, eBay ...
                              https://www.ebay.com/itm/28354481514...Bk9SR4Sq3u3kYA
