stringer help
  • mrd72
    • Oct 2021
    • 70
    stringer help
    i used to run a stuffing tube with liner, i changer stuffing tube to run with no liner, but my teflon tube used to run the through the length of stringer, my new tube i cut flush with hull, do i need to run a small length of teflon liner in stringer now? theres obviously a difference of some clearance gap in the stringer with just running the flex shaft without any liner now.
  • Jesse J
    scale FE enthusiast
    • 7241
    Sounds like you need a bushing.
    I would definitely not use the same teflon as in your stuffing tube, you don’t want anything soft in there.
    "Look good doin' it"
    See the fleet
    • mrd72
      • Oct 2021
      • 70
      yeah wasnt sure if i need to put something in the stinger to take up the space that the teflon liner used to be.
