Propeller talk post
  • dasboata
    • Dec 2010
    • 3972
    Propeller talk post
    OK guys I will add stuff to this post as we go along, I'm ignoring any questions of what prop do I need on my set up,, For argument sake All model boat props were 2 blades in the 80's so when you wanted a 2 blade prop you asked for a 440-450-460-470- ect,,, now when the 3 blades came out or got discovered back then they became 440/3-450/3-460/3-470/3 ect,lets all get on the same page
    • 4338
    What's your preferred method to describe an ABC prop (1715 for example) in terms of the rake angle and blade area, 1715 17-45?
      Why not use the manufacturer’s designation: 1715-17-45(2) CLL?
      • dasboata
        • Dec 2010
        • 3972
        1715 I'm assuming 2 blade 17* unless told 1715/3 but now with all the new ABC props I need to be careful
        • photohoward1
          • 1781
          17 is the diameter 15 is the pitch angle. if you multiply 17 times 15 it equals 2.55” of total pitch. For every turn the boat travels 2.55”. There is slip. Can’t be much simpler.
            The problem is how to ask for the exact ABC prop you want.
            diameter - pitch ratio - rake - blade area - number of blades - chopper/cleaver - left or right hand
            Use the maker’s prop designation. Can’t be any simpler - if you want to identify a specific ABC prop.
            • dasboata
              • Dec 2010
              • 3972
              2017 ABC prop chart
              • T.S.Davis
                • 6266
                I had trouble where I asked for props he hasn't even designed yet. Like I wanted something in particular that doesn't exist. That'll learn' me! Check the danged chart.
                Noisy person
                • Alfa Spirit
                  • 2183
                  Very easy
                  • dasboata
                    • Dec 2010
                    • 3972
                    good Visual the 10* is a lifter it lifts the transom and as it does that it lowers the bow as the rakes get higher there is less transom lift
                      • 4338
                      Cool, I didn't know the relationship between rake and lift. Does the rake angle change the thrust cone too?
                      • dasboata
                        • Dec 2010
                        • 3972
                        yes Ryan you can visualize the thrust will be tighter on the higher rake props
                          • 4338
                          Ok, makes sense. Does a narrower thrust cone mean less forward propulsion? Does a narrow vs. wide cone matter when considering a boat that turns vs. SAW?
                          • dasboata
                            • Dec 2010
                            • 3972
                            common sense says yes,, tighter thrust cone more thrust , I don't think the turns matter if your using a strong enough servo
                            • dasboata
                              • Dec 2010
                              • 3972
                              [QUOTE=Alfa Spirit;735707]Hummm ...
                              [IMG]ht
                              this is not show and tell please remove your post this is a informative contributions subject
