props????
  • RCBoaterGuy
    replied
    Here's an excellent thread for the new BJ29v3's... http://forums.offshoreelectrics.com/...C5-plugs/page2 - might wanna follow make-a-wake's advice & post your questions there. That'll give you the opportunity to share the results of your tests for the benefit of all, just as others have.
    Originally posted by luv2fly27 View Post
    Ok thanks! Yes it is the 2000 kv motor. I tried 4s out of the box and it wasn't very fast thus went 6s which was much more fun. My motor and ESC are barely warm to the touch after running for 7-9 minutes. Was just looking for an easy upgrade to gain even more speee in a super flat pond I use. Sounds like I should try the x438 or x440. Any preferences? Thanks Again and sorry for not starting a new thread I'm new to the site :)
    Leave a comment:
  • luv2fly27
    replied
    Do you think I will notice an increase in top speed with the upgraded prop as compared to the stock prop? If it's 2-3 mph im guessing it's not really worth it. If 5-10mph I'll probably spend the money. Thanks!
    Leave a comment:
    replied
    You can start with a Graupner K series in the 38-40mm range for testing, 6 bucks each, then move to a permanent prop like the Octura
    Leave a comment:
  • luv2fly27
    replied
    Leave a comment:
    replied
    If its the 2000kv motor i think 6s is overboard................if you want to run that though a 442 is too much prop, x438 or possibly x440.
    As a friendly reminder to a new member, in the future its best to start your own thread with a question about your own boat which is completely different from the OP's twin larger Cat.
    Leave a comment:
  • luv2fly27
    replied
    Blackjack 29 v3 props
    any suggestions for the best prop for the new blackjack 29 v3? Looking to run on 6s. From what I've read an Octura x442 S&B seems to be the best bet?? Any others to get top speed?
    Leave a comment:
  • launchpad
    replied
    and the 3674's a more than sufficient to get that boat haulin butt
    Thanks for the info.........
    Leave a comment:
    replied
    Originally posted by launchpad View Post
    the motors I am using are 3674-2200kv.I mentioned the 4074 because I have 2 that are 4074.Hope this clarifies the sizes.
    Leave a comment:
  • launchpad
    replied
    props
    Sorry about that;the motors I am using are 3674-2200kv.I mentioned the 4074 because I have 2 that are 4074.Hope this clarifies the sizes.
    Leave a comment:
  • RCBoaterGuy
    replied
    Yes he most certainly can!!
    Chris,
    Received mine today - GREAT JOB!!
    Now that's how they're supposed to look
    I knew those bozo's in California screwed me over (thank God for PayPal), you just proved it.
    That's was my first order, but it most certainly will not be my last.
    Keep up the good work!
    What ever you decide I can help you with a race prepped set of props thanks chris
    Leave a comment:
  • dasboata
    replied
    Leave a comment:
    replied
    thanks guys for all the info;i now have to consider all the options then try one.will keep trying different combos.goal is to get 60 miles an hour. I have set 4074 leopards I will try.does anyone know anything about the turnigy 180;with extra capacitor bank.
    again thanks
    What would you like to know? They are good, strong, handle 6s well with BEC disconnected and have an LVC issue which is an easy fix.
    Leave a comment:
    replied
    Just realize that every prop suggestion given was with the 3674 2200kv's...................you have 4074's of unknown kv in the picture now..........
    Leave a comment:
  • launchpad
    replied
    again thanks
    Leave a comment:
    replied
    I wouldnt go above 5s, 4s is plenty and will be quite fast. A pair of counter rotating x447's would get you moving out on 4s, 442's for 5s.
    Leave a comment:
