Can I use Y547 on the Zippkits JAE 21 rigger?
    • 5660
    Like the title says, I have a H7 that somehow I feel that is out of balance and not thinned properly. I have a wonderful Y547, but I am an illiterate when it comes to props and just want to ask.
    Motor is TPPower 3640 7D ( 3670/2100kv), Seaking 120A ESC with Cap bank. Dinogy 5000mah, 65C 4s.
    Thanks!
  • Shooter
    Team Mojo
    • Jun 2009
    • 2520
    It certainly doesn't seem out of the question. Diameter and pitch are very similar (H7: 47.5x72) (Y547: 47x72.3). Probably comes down to the lift characteristics of that prop for your rigger.
    I might give the Y547 a try on my P Sport Hydro as well. The Y series worked well on my Vegas years ago.
      • 5660
      Thanks, might try it today and report back!
      Sent from my Droid using Tapatalk 2
        • 7990
        I use that prop on my P-Mono and it works well due to its low lifting characteristics. You don't want a lifting prop on a JAE, so it may work very well for you.
          • 5660
          Fluid, thank you so much! I did run this awhile ago, had a radio issue so couldn't strectch my legs.
          Subjectively I thought the H7 had a bit of an edge interms of top speed, but the Y547 certainly worked well.
          For my thirst of knowledge, may I ask as to why this particular rigger would to well with a prop that has low-lift ? I thought riggers welcomed lifting props. Or that all this time I had it wrong?
          Thanks in advance!
          • martin
            • 2869
            The JAE works well on x,y & m series props as well as the usual high lift hydro props like the H7.
              • 7990
              The designers of the JAE do not recommend lifting props, they are not required. The rear ski supplies all the lift needed, lifting props are less efficient since their thrust cones are wider than needed and waste energy. IME props like the H-7 etc work better with some/most of the lift removed.
              Riggers without rear skis need a lifting prop to keep the transom up, that or some down angle on the strut.
                • 5660
                Thank you!
                  • 5660
                  Thank you for your explanation!
                    • 9479
                    curious to hear of your results with this prop on your rigger
                    I run a 1455 on my PSpec powered JAE
                      • 5660
                      I was plagued by a radio issue, I can only say that subjectively the H7 had an edge over the Y547, but I would not draw any conclusive judgement on that, need more testing. Sorry, I wish I could be more articulate, this is a new experience for me ( rigger) that is.
                      Thanks for asking though!
                      • martin
                        • 2869
                        Zippkits sells a 1450 (modified by them to 46.5mm diameter) to use on their 21fe rigger & cheap @ $12.
                          • 5660
                          Thank you very much for the heads up! ALso how does the CNC1450 work? Too large perhaps? ( 50mm, not reduced)
                          • ron1950
                            • 3024
                            I have to try the y547 on my p mono.....I gota stop reading these threads now its back out to test and all that stuff when I was so happy with it on a m445 :)
                              • 5660
                              Well, I did more runs, the Y547 was GPS'ed at 95 k/h ( 59m/h) Zippkits JAE second run 004.jpg
                              the H7 was clocked at 92 k/h ( 57m/h) Zippkits JAE second run 003.jpg
