x457 prop
  • rude5150
    • Feb 2014
    • 339
    x457 prop
    Anyone know about how many amps will the X457 prop pull?
  • rude5150
    • Feb 2014
    • 339
    How fast should I be go with a X457 prop?
    • photohoward1
      • 1629
      Need a whole lot more info. When I put it on my Open Mono on 8s it pulls 300amps. If I put it on my retrieval barge it pulls 25amps. If I leave it on the bench it pulls "0" amps.
      • Chilli
        • 3067
        Hull type? Hull lenth? What motor? What Voltage?
        Mike Chirillo
        www.capitolrcmodelboats.com
        • rude5150
          • Feb 2014
          • 339
          Catamaran,29", tp 4050 2220kv, 6s
          • egneg
            • 4664
            Way to big it will
            IMPBA 20481S D-12
            • Chilli
              • 3067
              Providing the motor size is adequate for your hull (Im not too familiar with the TP Motors). For sport running for a couple minutes, 4S with a prop in the 40-45 mm range would be much better on a motor in that KV range. For a few quick SAW passes on 6S I would still stay in the low 40 mm range because your RPM's on that motor on 6S will be very high. And that's providing your ESC can handle the amps.
              Mike Chirillo
              • ron1950
                • 3024
                with your set up I run a m445...I have a x457 on a 47 in mono with a cc 2028 motor....you will blow that 2200 motor up if the esc doesent make magic smoke first
                  • 7990
                  I ran a Castle 1515/1Y (2200 Kv) motor on 6S in my SAW recordholding 32" cat, and with a Prather 235 (about like an x550) ran near 90 mph with spikes of 350 amps. An x457 would spike well over 450 amps with an average around 350 amps - my guess anyway. Don't do it.
                  • keithbradley
                    • 3663
                    On a twin I would expect around 480A if the motor was actually capable of it, more on a single.
                    www.keithbradleyboats.com
                      On your miss geico? Your not being serious are you? Lmao
                      • rude5150
                        • Feb 2014
                        • 339
                        Wow, I am loving the feedback and I would have tried it. Im so glad you guys gave me the heads up .
                        Great job guys.
                        • rude5150
                          • Feb 2014
                          • 339
                          How fast should my geico 24 Tp4050 2600kv 180 esc 4s with m447 prop? How fast and how many amps will I draw?
                            No one can tell you that man. I've had the strut placement drop me almost 10mph. Invest in a data logger and gps to know these answers. Everyone else has.....
                            • rude5150
                              • Feb 2014
                              • 339
                              Ive got all mentioned. Ill go test it.
