Prop Suggestions - 22.5 Mono
  • gfm1135
    • Aug 2012
    • 177
    Any suggestions for prop for 22.5 mono running 2860 3400kv, 120a ESC. I tried running on 3s but i think it was to much. I am going to try it on a 2s. Looking for prop suggestions. Thanks!
  • gfm1135
    • Aug 2012
    • 177
    Running an Octura .150 cable system for 3/16" props.
      • 6057
      On 2s I'm thinking an x440/x442...........possibly even an x637
      • SirBudman32
        • Aug 2011
        • 701
        Is the mono you are talking about the R2 Hobbies Arowana? If it is I have one ( wife's boat ) It has a 2223 2900 out runner running on 3s 2200 batteries and running a 35mm prop doing 25-30.
        Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
        • gfm1135
          • Aug 2012
          • 177
          Yes thats the mono.
          • SirBudman32
            • Aug 2011
            • 701
            I have a wire drive in mine with a 1/8 inch prop shaft and run both 32 and 35 mm props on it and it flies for a little boat. Just can't get it to self right it's self.
            • gfm1135
              • Aug 2012
              • 177
              I have no issues with self righting. I tried running it on 3s but it kept going airborne. flipped over each time. going to try 2s
              • SirBudman32
                • Aug 2011
                • 701
                where do you have your strut set? mine is level with bottom of the hull and I put on a set of trim taps. Runs real dry and flat.
                • SirBudman32
                  • Aug 2011
                  • 701
                  Here is a small video of wife running hers with me and my Sv27
                  • gfm1135
                    • Aug 2012
                    • 177
                    Yes strut is level to the bottom. Both boats look like there are running great!
                    • gfm1135
                      • Aug 2012
                      • 177
                      Did you have an issue with chine walking? Mine walks pretty bad.
                      • SirBudman32
                        • Aug 2011
                        • 701
                        No, always runs smooth
                        • gfm1135
                          • Aug 2012
                          • 177
                          I thought maybe it had to due with all the weight on the port side.
                          • SirBudman32
                            • Aug 2011
                            • 701
                            I have everything but the rec. on the port side.
                            • gfm1135
                              • Aug 2012
                              • 177
                              Thanks for your responses. I raced cars for years. New to boating. Lots to learn.
