Prop Suggestions - 22.5 Mono
I'll take some of mine and put them up in a bit.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
Here is a video of wife and daughter running together.
Can you get a better pic of that transom area flipped the right way.
The mouting of the strut looks suspect to me. Is it loose? Looks like its pinched on the transom side. Wonder if its moving around on you.
Thats a pretty big motor for a small boat and the Kv is way up there. Try running it on 3s but with a much smaller prop- like a 30-32mm. What prop is on it now? Sounds to me like its a big motor, lots of RPM and to big of a prop to keep it in the water.
Im one of the other guys he runs with and I setup that 22.5". I used the 55mm length 4mm stinger and reamed it for 3.16" lead teflon bushings. Works real slick for $6! :) Fits the smaller boat nicely too.
You can fill those extra holes easily with epoxy and micro balloons and sand smooth.
Maybe Budman can get a picture of the transom and a side view showing stinger.Last edited by Basstronics; 10-27-2012, 09:23 AM.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)
I'll post another pic as soon as I can. The bracket mount is pinched. It was like that when I received it from OSE. I should probably returned it to Steve but as usual, wanted to get it running and didn't want to wait another week. It's got a 438 prop on it. Thinking of trying 2s. It is a Leo 2860 3400kv. I emailed OSE and that is motor and strut he suggested???
You bought this boat from Steve @ OSE? Or the strut?
I wont comment more on the strut until there is a better pic, but it appears to not look right.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)
Ya that strut isnt mounted right at all. How the hell is it even mounted? I dont see any screws in the 4 holes to the transom? What are the screws next to it doing? Ive never seen a strut with 4 mounting holes and two ears off the side. I would venture to guess thats a huge part of your problem- setup not done correctly.
Also that front bolt is squishing the angle. That bolt if its not going thru the actual strut is doing absolutely no good.
I would ditch whatever scheme that is. Straighten out that angle. Mount it correctly with the 4 bolt location.
Given the current setup I dont see how it could me mounted solid or reliably...42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)
That looks like a cast aluminum Octura strut setup, I have one on a small hydo, they are fine mounted by the two ears in a small setup, but that one is messed up, shouldn't be squished together like that, you don't need that one bolt in there at all, it does nothing, you only need the one through the strut.
You'll have to straighten the one side out, then I'd fill the holes in the hull and mount it with the 4 holes and smaller bolts four 2-56 screws and blind nuts will be fine and fit the holes perfectly if I remember right.
Be hard to drill correctly on the one side if you decided to use the ears again, too close to the existing hole. Just me but I couldn't have it mounted by the ear on one side and the 2 holes on the other, OCD when it comes to rc boats.
A bit of work with a file and some wet/dry sandpaper to take off the extra casting flash makes them look a little nicer IMO. Couldn't stand looking at the "knobs" on top of mine.
CheersIf my boats upside down then who owns the one I thought I was driving the last two laps?
