Revolt 30 how too hit 70mph
  • RandomHero
    • 104
    #46
    Lol I cut 5 strips of 1/8 inch stainless steel one runs uP the middle 4 up front epoxy them down then did the whole bottom with a good layer of it then the foam !! Thanks!!!.....
    • RandomHero
      • 104
      #47
      I run 1 4s And the LVT cuts off at about 60% of battery
      • Make-a-Wake
        FE Rules!
        • 6057
        #48
        You can lower the LVC to 3.0v, or 2.8v for more runtime.
        • RandomHero
          • 104
          #49
          Will that hurt the battery's ? Or is it just the esc going nuts?
          • Make-a-Wake
            FE Rules!
            • 6057
            #50
            The T180's quite often wont allow you to use 80-90% of your pack, they LVC early, especially with a 1p setup like yours. I went to a 2p in my Pursuit and it stopped happening. Setiing it at 2.8v is not recommended, but I do it and have had no issues with my batts, 3.0v and you're fine for sure.
              • 9481
              #51
              what lipo are you running?
              • gyrotron
                • 499
                #52
                [ATTACH=CONFIG]83796[/ATTACH][ATTACH=CONFIG]83795[/ATTACH]
                That was a sick ride. Great setup appreciate the pics. How much weight do you think you added to the hull?
                • Jersey Crewmax
                  • 495
                  #53
                  Thats a x645 the motor and esc are running at 91*F can i go with a BIGGER prop?
                  Looks awesome, makes me want to
                  Look into a Revolt.
                  • highflyerbill
                    • Jul 2011
                    • 206
                    #54
                    That is one scarry handling boat . Looks like when you touch the rudder wheel you have to be ready for it to go any where . It's an accident wating to happen . A boat at 55 or 60 that's almost out of control is dangerous .
                    • Sobie2
                      • 15
                      #55
                      That is the video that pushed me over to fast electrics! I ditched the idea of resurrecting my old Prather Deep Vee 31' Outboard after coming across this video. The weekend before I had my boat running and I broke a driveshaft, plus I never did get a full tank of fuel run on it. I started that project back in 1993. Electric power is awesome.
                      Sobie2
                      • kevinpratt823
                        • Aug 2012
                        • 1462
                        #56
                        and here's how you post a youtube vid, you were close, the two brackets should look like this without the spaces, its the only way i could show it here without it thinking there was a video.
                        [ y t ]
                        [ / y t ]
                        Actually, there is a little icon of a filmstrip at the top of the reply window, at about center. When you click this you just paste in the link and it does it for you now.
                        My private off road rc track
                        • MAMBA2200
                          I need a scooby snack
                          • 1347
                          #57
                          just how fast is this boat ever gps checked this boat ???
