how to you measure a prop to determine it's diameter
  • dasboata
    • Dec 2010
    • 3152
    Originally posted by egneg View Post
    The indicator is turned 90* and a wiggler is attached.
    Whats a wiggler ? can I see some pics of it turned 90 * with the wiggler ? yhanks Chris
    • egneg
      • 4664
      Sure ... I will take some pictures tomorrow.
      IMPBA 20481S D-12
      • dasboata
        • Dec 2010
        • 3152
        And I will show you mine !!!! LOL
        • egneg
          • 4664
          We might end up in jail !
          IMPBA 20481S D-12
          • Doug Smock
            • 5264
            Oh Noooooooooo!!
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • egneg
              • 4664
              This isn't the exact setup as I did this so you could see what a wiggler is.
              IMPBA 20481S D-12
              • dasboata
                • Dec 2010
                • 3152
                yea ok so how do you measure degrees of travel Its impossible to measure pitch with that angle and set up this is what you need
                • egneg
                  • 4664
                  I have the Hughey pitch gauge. to measure with. In the previous posts I said "check" blades to see if all things are equal. And the picture was not the setup but to show what a wiggler is.
                  Thanks for showing yours!
                  IMPBA 20481S D-12
                  • dasboata
                    • Dec 2010
                    • 3152
                    Thank you, it would be good to do a quick check. This is what I use to make sure all the blades match. I can also use it to check pitch with a gizmo I made.
                    OK thanks Chris
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 6958
                      Originally posted by D.Smock View Post
                      Kevin Sheren made these cool tools for checking diameter while making sure both blades are the same. 3/16 and 1/4" mandrels
                      When I got mine I was suprised how much some of my props were off.
                      Doug
                      It took me A WHILE to figure out that to get the correct/accurate reading of a prop's diameter using this tool that you have to add half the diamater of the prop holding shaft ( 1/2 4.76250mm = 2.381 mm) to the caliper reading, then double that number. Until I realized that, I thought that all my props were much smaller in diameter than claimed
                      • dasboata
                        • Dec 2010
                        • 3152
                        I have one from Kevin also,, the problem with them is that once in a wlile, you hit one of the buttons, by mistake, and it resets on you ,,then you have to take the alum block off to reset the thing !! other then that it is a good idea chris
