how to you measure a prop to determine it's diameter
  • Boomer
    • 285
    What is the correct way to measure the diameter of a propeller? I took a picture showing how I am measuring a propeller, but even with a digital micrometer, the props I measure don't seem to match the advertised diameter.
    Please share the proper points to use to get the correct diameter measurement.
    Thank you
    Boomer
  • Steven Vaccaro
    Administrator
    • 8724
    You have it right.
    Lots of the Octura props wont measure what they are listed at. It seems they use different molds or experience shrinking on some more than others.
    Steven Vaccaro
    • teach
      • 509
      Also as you sharpen and balance a prop, some of the tip usually will get taken off lowering the total diameter. Same for rounding the tips.
      • martin
        • 2869
        All casting shrink when material is solidified after casting so patterns must be made larger to allow for shrinkage. I suspect some manufacturers copy other propellers & simply take their mould from some one elses finished props. Saves a fortune to take an allready good prop & just copy but you end up with an undersize prop casting because the copied original was proper finished size. By the time a mould is taken the mould ends up finished size & them when the props are cast in this mould you get the relevent shrinkage. Aluminim shrinks around 6% & copper based materials around 4%. This is why some copper based castings with no filling just flash removal should be a 40mm prop but are 38mm +. Thanks Martin.
        • Boomer
          • 285
          Thank you for each reply! Thought it was me. Usually is, so it is nice to know I was doing something the right way for a change!
          Boomer
          • Doug Smock
            • 5264
            Kevin Sheren made these cool tools for checking diameter while making sure both blades are the same. 3/16 and 1/4" mandrels
            When I got mine I was suprised how much some of my props were off.
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • westbeach
              OSE Rocks!
              • 951
              Hey Doug, do you have a close up on one of these handy calipers? Thx
              HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
              • Doug Smock
                • 5264
                I'll post one tomorrow.
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • Doug Smock
                  • 5264
                  Here you go.
                  If I remember right Kevin was letting these go for $65.00 shipped . You can contact him here if you are interested. Gas_dir@yahoo.com
                  If you get one of these be prepared to spend a bit of time with your prop box. Like I said, I was suprised how many props I had that were off. This tool is well worth the money.
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • Steven Vaccaro
                    Administrator
                    • 8724
                    Originally posted by D.Smock View Post
                    Here you go.
                    If you get one of these be prepared to spend a bit of time with your prop box. Like I said, I was surprised how many props I had that were off. This tool is well worth the mo
                    Doug
                    Very cool. I have to buy or make myself one of those!!!! Probably buy one for that great price.
                    Steven Vaccaro
                    • egneg
                      • 4664
                      Doug is the pin on center with the jaw for the different pin sizes?
                      IMPBA 20481S D-12
                      • Doug Smock
                        • 5264
                        Yes sir.
                        D.
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • egneg
                          • 4664
                          Yes sir.
                          D.
                          Thank you, it would be good to do a quick check. This is what I use to make sure all the blades match. I can also use it to check pitch with a gizmo I made.
                          IMPBA 20481S D-12
                          • dasboata
                            • Dec 2010
                            • 3152
                            You can check pitch with that I would like to know how as pitch is checked on the face of the prop
                            • egneg
                              • 4664
                              The indicator is turned 90* and a wiggler is attached.
                              IMPBA 20481S D-12
