TRAXXAS 1/16 motor and esc in a mini mono.
  • Garrett
    • Mar 2012
    • 140
    Has anyone tried this yet?
  • bikergreen
    • 427
    that motor is only rated to 25a constant - almost picked one up until I found that out, I don't think it will handle the load very well.
    • Garrett
      • Mar 2012
      • 140
      I've got this motor and esc in my RC air boat. But that's a different hull and characteristic.
      • bikergreen
        • 427
        air boat is less load I would assume but could be wrong. I'm sure it would work if it was propped really lightly
        • Southwest
          • 274
          The airboat has MORE load due to water surface of airboat compared to monimono. I would put a Leo 2550kv on 3s and a 432 octura prop. Now with using a high voltage makes it easier on esc and as a whole will run cooler. Car motors will use 2S voltage and not burn up. Just my 2 cents.
          • Garrett
            • Mar 2012
            • 140
            thanks, I'm still learning.
            • Garrett
              • Mar 2012
              • 140
              well, I hit up the local hobby shop, and bought a 40A ESC. it looked the same as the AquaCraft 20A ESC. And unfortunately it didnt fix my problem. it'll run for about 5 minutes, then stops. Its like the motor wont spin, or has a spot where it wont turn. hard to describe. Guess I should get an inrunner for it and quit messin with the outrunner motor.
              • Eyekandyboats
                • 1935
                Check your motor timing on that esc you got. Could be a issue. As out runners like higher timing generally
                Sent from my iPhone 5
                EYEKANDYGRAPHICS
                www.rclipos.com
