JAE mini sprint 109$
  • lectriglide
    • 538
    #61
    electric - are you using the same motor as the prototype? I'm looking for something compatible and just curious what you are running.
    • electric
      • 1744
      #62
      Yes, I am running the turnigy 4400kv that was orginally recommended when they went on sale.
      • electric
        • 1744
        #63
        52mph
        holly crud, I did not think these were going that fast
        The big one..not the mini.
        • Alexgar
          • Aug 2009
          • 3522
          #64
          The renegades do 40 so it's only a matter of time before the mini sprint take on the 50 mark
          • Rumdog
            • 6453
            #65
            Outrunners will run hotter obviously. 160 is expected. That would be acceptable by my standards.
            • wparsons
              • 461
              #66
              I bet if you could fit a leopard 2860 in one you'd hit mid 50's if it stays on the water. You'd need a bigger ESC as well, and the weight would help keep it down a bit.
              Light travels faster than sound, so people may appear to be bright until you hear them speak.
              • martin
                • 2869
                #67
                With the right choice of $12 outrunner on 3s & $20 esc & correct prop you will hit mid to high 50s. This is my set up in a 15" mono v hull, Imagine how much faster a rigger is going to be over a mono v hull. Im aiming for 60mph on this budget set up,Martin.
                • HibridO
                  • 3
                  #68
                  http://www.youtube.com/watch?v=AuDAKRRtLA0
                  Which $12 outrunner?
                  • Rich
                    • 551
                    #69
                    How big of a motor with cooling jacket will fit in this little hull? And how long can the motor be?
                    • electric
                      • 1744
                      #70
                      Ran though two sets of packs today, the temp seems to stay round 160's at the end of each run. Thought about gettings some water cooling in there, but what a challenge with the limited space. I will stick with the air cooled for now.
                      This boat is unbelievably stable and the turns on it are something to see. Really nice handling boat. Good Job Zipp.
                      • martin
                        • 2869
                        #71
                        I think a Leopard 2860 might be to much at 1300w, This is a tiny boat. You may stand a chance with the less powerfull 2850 at 800w. Re getting these bigger diameter because of water cooler & longer can water cooled motors in, The front of the motor will touch the front of the cowling so mods will need to be done to the cowling. You will have issues with the water cooler clearing the tub bottom, Not by a lot & not to difficult to mod by raising the motor up on the mount or using a bolt in mount so you could try different configeration motors & sizes. Im sticking for now with my $12 outrunners which im sure i can get close to 60mph. I just get an extra buss knowing these speeds are capable with such cheap & simple motors. I must say a thanks to Joe at Zippkits for producing a superb quality kit, Everything in the kit fitted perfectly & also the JAE team for their hard work on the design of the boat. Im about 75% + paint their so cant wait to run it. Martin.
                          • 9479
                          #72
                          Oh, so maybe mid 40's with the mini?
                          • electric
                            • 1744
                            #73
                            Hard to guess with the size diference in the boat. Tempted to try, but I will leave it at that without my datalogger hooked up.
                            • Joe Petro
                              • Dec 2009
                              • 10
                              #74
                              Since the HK brushless motors are so hard to get, we ordered some directly from the manufacturer.
                              We will have 4400 and 3500 Kv motors in stock soon.
                              The 3500 motors should be good for the kids, and may even be pretty good with a slightly larger prop (we have the 432 in stock).
                              If you subscribe to our newsletter, we will notify you when these arrive...
                              Joe
                              P.S. Thanks for the kind words! Why not do a review on our site of the MS?
                                • 9479
                                #75
                                I think the 3500kv on 3s could rock real good!
