JAE mini sprint 109$
  • electric
    • 1973
    #31
    Just went on sale (in stock) this morning.
    • martin
      • 2881
      #32
      Yes ordered mine this morning with the $20 reduction for registered news letter subscribers, Their going fast (hopefully they will when built as well). Martin.
      • Doug Smock
        • 5359
        #33
        Originally posted by SweetAccord View Post
        I like the JAE stuff but for less and all built and two inches larger you can get this:http://www.r2hobbies.com/men/proddet...od=rcbt0401005
        It's big brother seems successful.
        http://forums.offshoreelectrics.com/...ad.php?t=23946
        Or not.
        http://forums.offshoreelectrics.com/...ad.php?t=25105
        I'm sure you'll see pre built minis by qualified builders before it's all said and done.
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • martin
          • 2881
          #34
          Yes the R2 Hobbies hydros are cheap to buy, But is it worth the hassle as Doug has pointed out in the thread still running on rebuilds the are neseassary to get a good reliable boat. They also have a question mark over the quality of the ply wood they use, I may be wrong but it looks like packing case quality ply. Its certainly not birch ply. They are cheap though. Martin.
          • pescador
            • 503
            #35
            Looks like I got the last Sprint.
            Namba District 16
            1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
            • NativePaul
              Greased Weasel
              • 2770
              #36
              Dagnammit, why did I have to go to work today, I missed out.
              • martin
                • 2881
                #37
                Zipp kits sold out in 90 minutes but expect to have more stock Wednesday. Martin.
                • martin
                  • 2881
                  #38
                  Zippkits have Mini Sprints back in stock but not many left. Martin.
                  • Joe Petro
                    • Dec 2009
                    • 10
                    #39
                    MS kits back in stock. Now also available pre- built.
                      • 9481
                      #40
                      Awesome!
                      • electric
                        • 1973
                        #41
                        Wow..the pre-built ones sold out in a like a second... I am in the middle of a build on one these, going well ...
                        • §Bodo§
                          • Dec 2010
                          • 13
                          #42
                          Hello,
                          what motor do you recommend for this model. The motor zippkit recommended from hobbyking is on backorder. Will a Leopard LBP2848/9T 4370KV fit in (mounting holes and diameter with/or without? cooling jacket). As I understand they drive the hobbyking motor without cooling?
                          Regards
                          Bodo
                          • martin
                            • 2881
                            #43
                            The bolt spacing on the mount is a standard 19mm centres so the Leopard motor will fit the mount, The Leopard motor is an inrunner so needs a water cooling jacket which obviously will make the motor a bigger diameter so you may have issues with the water jacket not getting low enough in the mount without touching the tub bottom. The motor they recomend is an outrunner so therefore is air cooled. Martin.
                            • wparsons
                              • 461
                              #44
                              The leopard motor is also longer and may not fit under the hatch. Here's a few others that might work from HK, no experience with them though so you may want to read the reviews.
                              http://www.hobbyking.com/hobbyking/s...idProduct=8137
                              http://www.hobbyking.com/hobbyking/s...idProduct=6387
                              http://www.hobbyking.com/hobbyking/s...idProduct=9257
                              http://www.hobbyking.com/hobbyking/s...idProduct=8616
                              The lower kv motors would require a different prop, but there is another 4400kv one in the above links.
                              Light travels faster than sound, so people may appear to be bright until you hear them speak.
                              • martin
                                • 2881
                                #45
                                If your using the kit then motor length shouldnt be an issue as it comes with a cowling & not a flat hatch cover, Ive got the kit in front of me ready for build & the main issue would be clearance on the tub bottom with the water jacket. It could be modded to take the Leopard motor by filing the mount holes to raise the motor a bit, Just depends how much you would need to raise the motor though. You would also have to align the stuffing tube to suit the slightly higher drive line of the motor. With the 28mm outrunner motor fitted in the mount theirs around 3.5 mm from the motor can to the tub bottom at its lowest point not sure if thats enough for a water jacket to clear on a 28mm can inrunner + jacket. Martin.
