Mini air boat
  • Basstronics
    • 2384
    Mini air boat
    Another project! Yippee!!!
    Looking to build a mini air boat. I want to use my Mystery D2632 3000kv outrunner & 30A esc.
    Im looking at 16" long 8" wide.
    Trying to get an ideal prop size worked out so I know how to build it.
    Going to work on the CAD model tonight some.
  • damfurst
    • 310
    I'll be interested to see how this goes. I think that you might only be able to run a 6 inch prop on your mystery motor. I have an Exceed 1800kv motor that anything over a 7" will heat the motor. I think I'm going to try and put it on the back of a extra Mini-C hull I have. Hope you post pics.
    • sailr
      • Nov 2007
      • 7128
      If it is a 26mm x 32mm outside dimensions, 3000KV, it should swing a 8 x 4.7 apc electric prop. My Storm outrunners that size but 1250KV will swing a 10 x 4.7 all day long on 3S lipo.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • Diegoboy
        • Mar 2007
        • 7443
        For reference...
        • bwells
          • Jan 2009
          • 847
          What about using an EDF (electric duct fan)? They are cheap and a lot safer. There was a build on here using one of these a while back.
          • Chop
            • Nov 2007
            • 522
            Originally posted by Diegoboy View Post
            Hey! I have that boat now!!!
            Hey! I built that boat…
            http://forums.offshoreelectrics.com/...ad.php?t=11893
            There is a fine line between "hobby" and "mental illness."
            • Basstronics
              • 2384
              I think I will stick to a prop.
              10-4 on that 8" prop size. I want to order parts this weekend.
              Its going to be a balsa-lite ply construction. I will end up putting a thin layer of fiberglass on the under side once I prove it in the pond.
              CAD model coming soon.
              • Basstronics
                • 2384
                I got the basic hull design done for now.
                Going to order the prop adapter and a few props this weekend.
                Attached is a PDF of the CAD file. Its still rough as far as the CAD goes. I have all the pieces figured out.
                The boat will have a 2 degree included V- 178 degrees. There is also a 1 degree on the rear. So if you build the motor flat to the top and use the design as is, the motor will be 1 degree angle towards the sky.
                Thoughts on these angles? I dont want to much lift but I would like to reduce drag- hopefully 1 degree is good enough.
                • Chop
                  • Nov 2007
                  • 522
                  In your section views you show the sides to be almost 90 degrees from the deck.
                  If you put the sides at about a 55 degree angle to the top deck the boat will slide around the corners rather that having to sharp edge to bite into it (making it more likely to tip).
                  • Basstronics
                    • 2384
                    Ah OK. I built this kind of like my lil swamp buggy...
                    I will put some angles to it tonight.
                    • Chop
                      • Nov 2007
                      • 522
                      Originally posted by Basstronics View Post
                      Ah OK.
                      Sorry, I'm no expert; build it the way you see fit.
                      I do see an obvious difference in the way the two boats (pictured in post #6) turn. The small one has straight sides and tips badly in turns; the large boat has angled sides and slides through them (the ducted fans lower C.O.G. helps with this too).
                      • sundog
                        Platinum Card Member
                        • Feb 2009
                        • 940
                        Yes, tipping. It would seem that 2 ducted fan units would do the same, only with a lower center of gravity. But I don't like the slow 'get up and go' in airboats. Was thinking of incorporating 2 ducted fan units on a jetboat (or a jet drive in a ducted fan boat) for quicker response.
                        • Basstronics
                          • 2384
                          Ok I got it done today and I got the parts printed out. Im going to start cutting wood now.
                          Attached is the overall then 3 sheets of 8.5" x 11" paper printouts. So if anyone else wants to build this they can.
                          I upgraded the wood to 3/32" Balsa. I added some 3/32" x 1/4" Balsa runners to help stiffen things up.
                          Will post pics later.
                          • Basstronics
                            • 2384
                            I just discovered the hard way that I bought 1/8" and 3/32" thick Balsa...
                            Dangit!
                            • Basstronics
                              • 2384
                              Update.
                              I need to build the motor structure now. Also have to figure out how I am going to do the rudder.
                              This is going to be a puller. Should I go with one rudder or two?
