1/10 scale hydro
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 270
    Originally posted by Gary View Post
    Just my 2 cents on my own boat for whatever its worth. 1521 1.5D , 240 Hydra, M645 prop, 25 volts 40-80 c batteries, 30 inch long Hydro, comes in at 8.2 lbs Boat has gone 85.3 mph and in this video consistent 80+ for 8 runs. http://www.youtube.com/watch?v=YvLAGyd3GuU
    thats cool video . Any body seen the h @ m eagle twin wing hydro its about 31 inches
      • Apr 2008
      • 270
      The 1521/1.5D will work great and should give mid-50s, but it really likes 2P as it does draw some amps. You may have a tough time getting 2P packs into that hull and maintain the currect CG; you'll probably have to add weight anyway. An alternative would be a 9XL or 10XL, these draw fewer amps but still give decent speeds and will swing a large enough prop for that big hull.
      As usual, it really depends on how much you want to spend, how fast you want to go, and how long you want to run.
      Could I Run 4s 1p 35c 5000mah and be fine still with a castle 240 with the neu 1521 1.5d
        • 9481
        That sucker is Awesome!
        • Gary
          • Jan 2009
          • 1104
          Thanks. She just whent 88 mph so im real close to my goal of 90+. I will find out wed. night
          H&M 1/8 Miss Bud 73 mph
          Chris Craft 16 mph
            • 9481
            Get the video!
            • Gary
              • Jan 2009
              • 1104
              Oh i will. This time i have it planned out so it will be better..provided the boat stays on the water LOL
              Chris Craft 16 mph
                • Apr 2008
                • 270
                I know this might be over doing it but what prop should I use with a 1527 1d 4s 1p set up in my 1/10 scale if I decide to use that motor I always like the extra power so it can be there thanks for looking
                • JimClark
                  • 5913
                  An X40 or an X42 maybe? Which direction are you turning Right or left?
                  Billy Graham
                    • Apr 2008
                    • 270
                    Haven ' decided could you give me info on both directions I think I ll go left thanks
                    • Gary
                      • Jan 2009
                      • 1104
                      I thought of trying that motor on 25 volts LOL but that would be a melt down for sure. But i bet it would be woth the video LOL
                      Chris Craft 16 mph
                        • Apr 2008
                        • 270
                        what speeds what I get out of a feigao 9xl on 4s1p 5000mah 30c or 35c and which prop should I use for speed and also suggestion for run time in my 1/10 scale T 4 HYDRO @ MARINE THANKS
                          • Apr 2008
                          • 270
                          which prop should I use on a 9xl and what cable should I use 187 or 150 on feigao neu
                          • jcald2000
                            • 786
                            .187 cable for sure!
