I have a 30" DV (22deg deadrise) on the build.
The sides are on and bottom is skinned. Foredeck is framed and will be skinned tomorrow.
Bottom hook
There is slight hook in the bottom in that when placed on a flat surface the transom touches and about 10" froward touches. There is a slight hollow between. I believe this is a common feature on many of the produced hulls such as the DF.
Is it good bad or otherwise ?
I have enough skin thickness to be able to sand most of it out if it has to go.
Spray rails
Attached is a sketch of two different spray rails I have seen.
I will initially build and finish the hull with out any rails.
If I fit rails then is there a preference for either of the two I have drawn ?
Do rails have to go all the way to the bow?
That will do for now. I am sure I will have more questions later.
Thanks.
Bottom hook
Spray rails
Thanks.
