It's true that raising the angle of the strut too much causes the hull to run very loose, & dropping the strut too much causes the hull to run too wet. Everything has a point of 'diminishing return'. It's a question of finding the right balance with the strut angle, the COG & the type of prop being used to get that slight nose up attitude of the hull in full flight. Again we are only talking about 1 degree or so.
Simon.
If you are using a flex drive, with either a strut setup or stinger type setup, I believe as low as you can get it is best for the exit.
As an example the centerline of the stinger on mine is 8mm above the bottom of the keel.
Paulwilliams.
I too have just been reading through your website. Great stuff. Going back there now for some more learnin'
Cheers.
Paul.
Simon.
Paulwilliams.
Cheers.
Paul.
