Twins with single drive?
    • 9479
    Thanks man!
    happy people make me smile..
    • Punisher 67
      Ignore list member #67
      • 1481
      Todd are you going to take a video of the run , curious to see how your project pans out .........................
        • 9479
        I will make a video if I can get this to work..
        • ED66677
          • 1300
          two BL motor on a single ouput tranny will require to use a one way bearing on each motor shaft, same as those use on RC heli for autorotation, but as others said a lot of engineering is needed to put this together!
          The only advantage you could get using a tranny, is to swap gear to change ratio, nowdays with the available range of motor (size and KV) this is useless and IMO just another source of failure.
          Emmanuel
          • DJS
            • Apr 2009
            • 19
            Kyosho Twinstorm 800's use this setup too.
              • 9479
              Most of us are aware how they should work
              I'm not looking to build one, I am looking to see if such a trans is out that can use XL motors..
              • bustitup
                • 3071
                i told you before the emax (old 3906 style) would be easy to modify and everything on it is balanced and centered and is made to hold 540 motors and is heavy duty
                here is under the tranny
                • 785boats
                  Wet Track Racing
                  • 3169
                  Mack Products make them. They're shown with motors but I'm not sure if they sell the gearboxes seperately.
                  You would have to check with them if they could handle the power & revs you are planning on using though.
                  Thinking about it though, you probably don't want a reduction gearbox just something with the two drive gears & the shaft gear all the same size. I guess that depends on the kv of the motors & the voltage you intend using. Just a thought.
                  Cheers.
                  Paul.
                    • 9479
                    [/IMG]
                    You told me?
                    Dude! I have a Brushless ERevo , the gearing is to low...
                      • 9479
                      Cheers.
                      Paul.
                      Score! Thanks Paul
