Twins with single drive?
    • 9479
    Does anyone know if someone makes a drive setup to use two 540 size motors driving a single shaft..
    I would like to try this in a cat that is setup with a single drive..
    Thanks
  • bustitup
    • 3071
    Thanks
    I was thinking of this...you could modify an emax or erevo tranny to work
    • D. Newland
      • Dec 2007
      • 1030
      The tough part is to engineer a pinion gear that can free-spin if one motor cogs, blips or otherwise shuts down for some reason (ESC failure let's say). But then you're left with 1 motor doing the work and instantly getting an amp surge, which will probably take out the other ESC.
      You're better off going with 1 bigger motor...but I know, the man in you wants to try it!
      • Diegoboy
        Administrator
        • Mar 2007
        • 7247
        Have a look at this. We use this in scale boats. 1 motor turns 2 props counter rotating.
        • Jeff Wohlt
          • 2716
          The old Super Hawaii used that set up. It would bolt up but the gears are for 1/8" motor shafts Not sure how well they would do but I ran mine on 12 -14 cells and never came apart.
          www.rcraceboat.com
          jwohlt5362@yahoo.com
          • egneg
            • 4664
            My Kyosho used such a setup but that was for 1/8 shaft brushed motors and 4mm drive shaft with a 2:1 gear ratio. I haven't heard of one being used for brushless applications.
            IMPBA 20481S D-12
              • 9479
              Well I am going to keep looking, and if anyone has any pictures or info please let me know..
              two motors into one drive..
              Thank you
              • domwilson
                • 4405
                You might want to call Ray at Fuller's Fast Electrics http://www.drcwebservices.com/ffe/ . He used to sell a transmission from Hughey that Ran dual 550 motors to a single shaft. MRP used to use the same thing on their Hydros. He may be able to point you in the right direction.
                Government Moto:
                • domwilson
                  • 4405
                  Is this what you're looking for?
                  http://cgi.ebay.ca/HYDROSPEED-606-7....513122001r4112
                  Government Moto:
                  • sjslhill
                    • 1514
                    Ed may still have some duals, I do but I'm holding on to my Hughey stuff. Maybe Fluid (Jay Turner) has one. I even have one that will hold 4, 05 motors!
                    • Himalaya
                      • Apr 2009
                      • 251
                      I believe this way is practical a few years back when motors are weak, brushless are not as popular as today. See what happened to E-REVO original to E-REVO BL, and you get the answer.
                        • 9479
                        Thanks domwilson and sjslhill and jeff, getting good stuff..
                        • crabstick
                          • 954
                          My question would be WHY ? unless you are planning to run brushed motors ? ?
                          There are some huge brushless motors that are capable of pushing big hulls at 80+ mph, why would you want to possibly complicate things by running two motors, two ESC's , two sets of cells, gears, etc etc, to me it seems like that would be introducing more possible points of failure and cost for a single drive.
                          Also consider the Gearboxes that you are looking at are most likely designed for brushed power and will probably FUBAR themselves with any good amount of BL power.
                          Please don't take this the wrong way, just stating my opinion based on my own logic
                          Matt.
                          www.rcboats.co.nz
                            • 9479
                            because I want to....
                            • crabstick
                              • 954
                              just because huh...
                              I wish you good luck and await the result!
                              Matt.
                              www.rcboats.co.nz
