exactly what i was thinking, thanks for giving me the thickness's. the only thing ray was concerned with was shorting the board. you never had any problems with that right.
need ideas on watercooling cuda 125
You are find as long as you keep them away from the lead-posts at the ends...Originally posted by 6S HYDRO View Postexactly what i was thinking, thanks for giving me the thickness's. the only thing ray was concerned with was shorting the board. you never had any problems with that right.
You may find you need to add some additional thickness... it's going to depend on which FETs your boards have... On some, what I did was add a piece of thin aluminum to them to get them to touch the FETs on both boards. Also, a piece of water-hose over the tubing where it is along-side the ESC will help to space the water-tubes away from the FET boards about the right amount and helps to keep them from slipping fore-aft...
This is all I've used for the past 4-years and have never had a problem. Just take care in the initial setup and you should be fine.Darin E. Jordan - Renton, WA
I think it's just two... one in the middle, and one on the outside FETs... The inside one does double-duty for both sets of FETs...Originally posted by 6S HYDRO View Posthow many plates are you using? i looks like 3Darin E. Jordan - Renton, WA
Darin, thank you for changing your picture! Looks like a different you!
It doesn't hurt that I've lost about 20lbs and workout at least 4-times a week now since the last pictures (Oberto clad) were taken...Originally posted by Flying Scotsman View PostNo kidding, younger and wiser
Being in great shape not only looks better, but it helps you handle the stresses of a raceday MUCH better, including helping you concentrate while driving...
I was not sure of the weight loss but knew something was very different. Good job.
There is a plate for each copper tube... which also corresponds to the number of FET tops that need to be contacted....... so there are three plates... One between the control board and the top FETS, one in the middle, and one on the bottom...Darin E. Jordan - Renton, WA
I was going to do the same but was not sure if the bottom of the plates (fets) would short anything out? I like the hydra set up with mulitple plates for each layer.
So this can be done okay?
Originally posted by Jeff Wohlt View PostI was going to do the same but was not sure if the bottom of the plates (fets) would short anything out? I like the hydra set up with mulitple plates for each layer.
Let me look at my 1/10th scale tonight, which is running a B125 ESC, and maybe take some better pictures so you guys can see what I'm talking about...Darin E. Jordan - Renton, WA
