i need some ideas or previous methods of watercooling a cc baracuda 125 speedo
need ideas on watercooling cuda 125
One cooling plate on top and one on the bottom. You can also add a cooling fan. There is a lot of info on watercooling the Himodel 200A ESCS. (HM 200A)
You can hold the cooling plates in place either by heat tranfer epoxy or heat shrink or epoxy...Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/
I know what your talking about, since that ESC used to be mineOriginally posted by 6S HYDRO View Postwouldnt that only cool one board of the esc when theres 3, or can i separate them and put in 3 of those.
. I couldn't figure out any solutions for water cooling it. The one they sell on OSE doesn't like like it would fit since there are three circuit boards on that controller. What are you putting it in?
Its in my fuller's blackjack, yeah i was over at ray fuller's house yesterday and we discussed cooling that sucker, i got a cooling plate for the top board and i think im gonna slide a metal plate thru the middle and then solder tubes to both ends sticking out.
Ray Fuller use to make a cooling kit, send him an e-mail. He may be able to help
fastel1@cox.net
Douggie
That ESC was the replacement ESC Castle sent me a few years ago. Ray actually rigged my SV27 with the original cuda 125 up in Washington, that's funny, it's come full circle... almost.Originally posted by 6S HYDRO View PostIts in my fuller's blackjack, yeah i was over at ray fuller's house yesterday and we discussed cooling that sucker, i got a cooling plate for the top board and i think im gonna slide a metal plate thru the middle and then solder tubes to both ends sticking out.
Castle had issues with cooling the .125 hence the Hydra series so it's tough but Im sure you'll get it figured out. Good luck man, it's a great controller that can handle a beating for sure.
DIDNT YOU READ MY POST- I WAS OVER AT RAY'S HOUSE YESTERDAY. IM LUCKY ENOUGH TO BE ABLE TO GO OVER THERE ONCE A WEEK.Originally posted by Flying Scotsman View PostRay Fuller use to make a cooling kit, send him an e-mail. He may be able to help
fastel1@cox.net
Douggie
You can also try a small cooling fan either 5V (power from receiver) or 12V, blowing into the ESC, if your water cooling is not effective.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
Paul, gently now. I did not read your post, obviously. What was his response? As he was the master of water cooling the Barracuda series.Originally posted by 6S HYDRO View PostDIDNT YOU READ MY POST- I WAS OVER AT RAY'S HOUSE YESTERDAY. IM LUCKY ENOUGH TO BE ABLE TO GO OVER THERE ONCE A WEEK.
Douggie
Here's how I've always done mine... .030" copper plate with 5/32" copper tubes soldered on. CPU Heat transfer compound on the plate, then slide them in onto the FETs and heat-shrink to hole them in place...Darin E. Jordan - Renton, WA
