Rudder pushrod-linkage
  • DISAR
    • Aug 2007
    • 1137
    I use these 2mm push rods, they are s/s. Tried to make thread with a 2mm die but couldn't. The s/s is very strong.
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=200280825529
    Do you know where to find 4-40 s/s? or 3mm s/s? By the way what is the diameter of the 4-40?
    I absolutely agree with the CF. Pushrod-clevis from CF.
    http://www.rcfastboats.com/
    • longballlumber
      • 3417
      I have heard of people using SS welding rods for linkage. If your linkage sections are straight you can use hollow carbon/fiberglass rod as a reinforcment.
      • DISAR
        • Aug 2007
        • 1137
        You won't believe it. I have these as well, 2 or 3 mm I think. They are super strong and much stronger than the ones I mentioned above. I tried to make thread in the past but no way, there4 left them aside, they are really difficult to bend as well. But now I can epoxy the clevis or ball joint on one side and on the other side the ez connector. I will find them again, thanks. These I got from a shipbuilding yard.
        • ozzie-crawl
          • Sep 2008
          • 2943
          i spend most of my time at work tig welding so i have a ready supplie of 1.6-2mm s/s rod, but found thicker rod at a local hobby shop they have 4-40 (i thought 4-40 was a imperial measurment of some kind but this may not be rite) they have them for planes with a threaded end with or with out clevis there made by du-bro http://www.shopatron.com/product/par...161.5165.0.0.0
          • DISAR
            • Aug 2007
            • 1137
            Is this rod s/s or galvanized?
            • ozzie-crawl
              • Sep 2008
              • 2943
              the ones i got are stainless steel
              • crrcboatz
                • Jan 2009
                • 1103
                If you want stainless steel, use bicycle spokes. They are VERY strong. You will need to silver solder your connections though.
                Curt
                • DISAR
                  • Aug 2007
                  • 1137
                  Thanks Curt. I will check on these as well.
                  Yesterday night I reassembled (again) the linkage. Tried to fit the s/s welding rods (I have 2, 2.4 and 3mm rods) soldered the threaded coupler but finally decided to use the 2mm rods which are threaded on one end, fitted a Sullivan clevis there (servo side) and an ez-connector that i found on the rudder side. Let's see how it will perform. Relocated also the servo as close as possible to transom.
                  • Simon.O.
                    • Oct 2007
                    • 1611
                    From an asthetic point of view I like to fit the clevis or ball end at the rudder and the ezi-connector at the servo (inside).
                    Your boat, your call.
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      on my boats i run a clevis on the servo side and on the rudder end its hard to explain look at picture
                      • Simon.O.
                        • Oct 2007
                        • 1611
                        You are Australian and you lot do most stuff backwards.
                        Clevis or ball outside, at the rudder horn , ezi-connector inside at the servo horn.
                        Really it is so hard ??
                        Wait untill I have the new rudder setup for a Cat I may build.
                        Designing and building the hardware is half of the fun, I have most of the rudder setup done.
                        • DISAR
                          • Aug 2007
                          • 1137
                          I ordered some 4-40 push rods and various connectors as well, just in case. I saw that the 4-40 is 0.093" diameter which is about 2.4 mm.
                          • ozzie-crawl
                            • Sep 2008
                            • 2943
                            this is were i should say somthing about sheep but will leave that alone
                            my rudders have that setup and and works rather well
                            on another note here is a link you may or may not have seen has some good info http://boatdesign.net/articles/tunne...sign/index.htm
                            • longballlumber
                              • 3417
                              I use these on the servo end (solder)
                              http://www3.towerhobbies.com/cgi-bin...?&I=LXK084&P=7
                              I use these on the rudder end up to 4S boats.
                              http://www3.towerhobbies.com/cgi-bin...?&I=LXD912&P=M
                              Just a note on the dubro swivel ball links. I get the version for the 2-56 then I redrill the plastic and thread in my 4-40 rod. Works Great. I also always use the speedmaster mini (.21)
                              rudder assembly. The hole in the rudder are are already the correct size to tap a 2-56 thread into it.
                              • DISAR
                                • Aug 2007
                                • 1137
                                Nice. Which 4-40 rod are you using? Is it s/s or galvanized?
                                There are the Dubro Heavy Duty 4-40 ball links available also which I suppose fit the 4-40 rods.
                                http://cgi.ebay.com/Dubro-Heavy-Duty...713.m153.l1262
