another mean machine set up
  • bustitup
    • 3071
    I ordered this motor cooler for my 1515 and 1512 neu's....will it work on my feigao 9xl?
    Product ID: ham-neu1512-1515
    Neu 1512-1515 Motor Aluminum Water Jacket
    • bustitup
      • 3071
      how do I program the himodel 200 8s version or do I even need to?
      how thick should I apply the grimracer grease on the flex shaft? and how often?
      should I solder the end of the flex shaft before crimping the flex hex on?
      please look at the pic and you can see I have two input cooler feeds...one on top of the rudder and one lower right in the picture...then you can see I have one output tube on the port side of the boat
      please give me opinions on how you would route all this add another output or use a "T" or "Y" inside the boat?
      • bustitup
        • 3071
        No one?
        • calcagno45
          • Mar 2008
          • 1006
          Grease should be apply after every run or every other run.
          Flex shaft ends should be soldered to avoid unravelling. But if you use a flexhex, you can get away without.
          As far as the 2 pickups, I would take the one off the sponson and just use the one on the rudder. I would also gut the hull and install an adjustable motor mount. Then place the electronics on the tunnel, and tape the hatch shut.
          My prop hasn't been wet in a while.
          • bustitup
            • 3071
            do you put that blue grease on pretty thick?
            thanks for the responce cal
            • calcagno45
              • Mar 2008
              • 1006
              I make sure its on there good enough and just wipe off the excess...
              • bustitup
                • 3071
                I'm thinking of starting off with the Feigao 9xl on one 5s with x442 prop....(because I cant see myself pushing the boat out into the waterfor the first time with a Neu motor in it)..LOL
                suggestions?
                also here's my attempt at 200 amp cooling mod
                • bustitup
                  • 3071
                  heres a picture of my rudder hardware I have about 4 to 4 1/2" rudder and a read here that you should have a 5 1/2 rudder to be stable in the turns...is this true or am I ok?
                  if I do need the longer rudder can I still use the harware that is attached to the boat and just buy the rudder only?...if so can you link me to it?
                  rudder
                  • bustitup
                    • 3071
                    ok I took everyones advise and removed most of the old gas fiberglass over the tunnel....i'm ditching this mount and fabing my own mount....little more sanding on the tunnel and clean with acetone then I will lay down the carbon cloth over the tunnel and install my new mount and wire this baby up....the o-rings and silicone sealant worked real nice mounting tne kb45 cooling can on the cc neu 2200 brushless....I used 400deg sealant ...I should never get hotter than that you think?
                    I'v got the front of the motor at 9 inches off the back transom
                    • bustitup
                      • 3071
                      I put the hull in the pool today and the auto bailers just let the water flow in like crazy.....are you mm owners plugging these up or what....... I know the bailers will let the water flow out when shes running but there will be times when the boat stops out in the middle of a pond.....I'm guessing the water would rise about 3/4" above the tunnel
                      • calcagno45
                        • Mar 2008
                        • 1006
                        Take them out and seal the hatch with tape! No water in at all!
                        • bustitup
                          • 3071
                          well I been pecking at her and she's real close....motor is mounted nice and tight....tunnel and motor mount are fibered in real nice and solid
                          very close to launch time
                          • bustitup
                            • 3071
                            Ok just got back from running it but used a Turnigy 180amp marine esc
                            it handled so beautifully but could get no speed or rpm...... definitely got something hooked up wrong
                            gps was only 23mph and I'm thinking one of two things that I can think of
                            #1 had the esc timing set to 0%
                            #2 don't know if I bound the new tactic 2.4 tx properly and not getting full power even though the trigger was pegged
                            any ideas?
                            • Jesse J
                              scale FE enthusiast
                              • 7241
                              Did you connect the batteries?
                              "Look good doin' it"
                              See the fleet
                              • DISAR
                                • Aug 2007
                                • 1072
                                What prop.? Your batteries are good? Reprogram the ESC, all parts. Does your shaft spin easily by hand? Is your coupler fixed tight? Make sure the batteries are connected right. These are some points to consider, there are more... like faulty motor or ESC but these are the last ones.
                                http://www.rcfastboats.com/
