Neu motor specs
  • Steven Vaccaro
    Administrator
    • 8932
    Neu motor specs
    I spoke to Steve Neu today about his motors. He cleared up some things for me. Also pointed me to a nice chart thats "kind of hidden" on the castle site.
    Steven Vaccaro
  • Darin Jordan
    • 9446
    Steven, to go along with that link, here is the link to some other Neu series motors:
    Neu 1100 Series Motors
    Neu 1900 Series Motors
    Neu 2200 Series Motors
    Darin E. Jordan - Renton, WA
    • Steven Vaccaro
      Administrator
      • 8932
      Thanks Darin!
      Mr.Neu just emailed me the entire spreadsheet.
      This link will get it all on one page.
      http://www.offshoreelectrics.com/neu-motor-chart.htm
      Steven Vaccaro
      • RCprince
        • Jul 2007
        • 1684
        Neu also have a 36mm motor out now called the 1415.
        The 1400 series fits in applications that require a standard 36mm diameter motor. The 1400 shares the same rotor with the 1500 series motor. This motor is perfect for cars,trucks and buggies that need a 36mm motor. EDF fliers will love this motor as it will fit in the Midi FAN as well as many other fans that require a 36mm motor. The shaft is 5mm. The first available versions are the 1415 but more sizes will follow. The P32 gear drive can be fitted to this motor.
        Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
        • ApacheDude
          • Sep 2008
          • 88
          There are a ton of options which is really cool, but how do you go about determining which one to try? I understand there is a little trial and error but what factors directly affect selection?
          Boats:
          Proboat Apache 24
          Proboat Blackjack 26 Brushless
          • Ub Hauled
            • 3051
            Guys, I need to find the place I saw it but there is a 1524 as well... pretty cool I thought...
            a little more power then the 1521 and a little more RPM then the 1527.
            • RCprince
              • Jul 2007
              • 1684
              I've seen them on line
              • Punisher 67
                Ignore list member #67
                • 1616
                Great info but it really would be nice if Steve updated the ohms on all the motors not just some of them , Can be a little frustrating testing them on paper.......
                Jan just scroll down they have the 1524's here
                • Ub Hauled
                  • 3051
                  yup, that's one of the site I found as well, but if you click on the picture, a 1521 shows...
                  hehehe, mystery sill looms
                  • Steven Vaccaro
                    Administrator
                    • 8932
                    Mr. Neu said there are 1524 motors made. They are made for ducted fan companies.
                    Steven Vaccaro
                    • RCprince
                      • Jul 2007
                      • 1684
                      Anything and Everything for electric flight, your electric superstore, Helicopter store
                      • Steven Vaccaro
                        Administrator
                        • 8932
                        Funny they have it's max rating at 5000-5500 watts. Considering the 1527 is rated at 4500, it seems a bit over rated.
                        Steven Vaccaro
                        • Ub Hauled
                          • 3051
                          Steven, since you have been in talks with mr. Neu, this may be a good question for him...
                          Just a thought.
                            Perhaps. Or it could be because the airflow in an FE ducted fan installation provides much better cooling than the typical heli or prop plane install. The motor is directly in the high velocity air stream from the fan, not at all like other installs....
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              Perhaps. Or it could be because the airflow in an FE ducted fan installation provides much better cooling than the typical heli or prop plane install. The motor is directly in the high velocity air stream from the fan, not at all like other installs.....
                              Probably.
                              I personally will still use fraction of the constant rating for my builds.
                              Steven Vaccaro
