What size esc do i require ?
  • Andris Golts
    • Jan 2011
    • 508
    Hi all just received a TP 4050 V1 1330 KV MOTOR IN THE MAIL .There was no amp draw chart include with the motor. I plan on installing this motor in my 34 inch wild thing mono on 6s 1p 5000 mah lipo i was told it could swing up to a 48 mm dia prop. What size esc do i require ?
  • Peter A
    • 1622
    OSE Raider 150 would do, other options are Seaking 180 or ztw 200.
      • 4340
      How will the boat be run? racing laps, SAW passes, sport running?
      • Alfa Spirit
        • 2183
        ZTW 150A High Voltage, perfect if you want to try 8S
        • Andris Golts
          • Jan 2011
          • 508
          Thanks to all for the replies . to answer fweasel mostly sport running with a possibility of racing or saw down the road. I guess for now i will use my Swordfish 220 amp pro + esc . Regards Andris Golts.
          • jaike5
            • 564
            My Wildthing is a 4s PL offshore boat. It's on the edge on 4s , 6s maybe a bit much for that size of hull.
            J.
            • jkflow
              • Aug 2021
              • 329
              You need to size the ESC to the motor, prop is secondary unless you want to mismatch completely.
              The 4050 specs as per OSE:
              Specs:
              Watts Continuous: 2350
              Watts Max: 5000
              Current is power (watt) / voltage
              4S ~ 15V
              6S ~ 23V
              5000/23 = 217A
              Most likely you will not get the max on 4S and you will stay below.
              I'd go with a 200A minimum.
