Hi all just received a TP 4050 V1 1330 KV MOTOR IN THE MAIL .There was no amp draw chart include with the motor. I plan on installing this motor in my 34 inch wild thing mono on 6s 1p 5000 mah lipo i was told it could swing up to a 48 mm dia prop. What size esc do i require ?
Tags: None
Thanks to all for the replies . to answer fweasel mostly sport running with a possibility of racing or saw down the road. I guess for now i will use my Swordfish 220 amp pro + esc . Regards Andris Golts.
You need to size the ESC to the motor, prop is secondary unless you want to mismatch completely.
The 4050 specs as per OSE:
Specs:
Watts Continuous: 2350
Watts Max: 5000
Current is power (watt) / voltage
4S ~ 15V
6S ~ 23V
5000/23 = 217A
Most likely you will not get the max on 4S and you will stay below.
I'd go with a 200A minimum.
