You don't need a tap on all of them if the pack was made correctly.....2 cells share one tap and they will always be the same voltage and charge the same.
Lipo's 2s2p vs. 2s1p
Can someone tell me if it's safe to connect two 2s1p team orion packs to make 2s2p. The packs that I have are 3200mah team orion race spec carbons. The packs use 4mm bullet connectors and I would like them to connect to one deans. If this is alright, can someone tell me what the connector I should make will look like? Should I run both posatives to the posative on the deans and the negatives to the negative?
Do you have a link? I did a quick sweep of the website and did not see the items you are referring to.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
LOL, no stress. Are you having dreams again of 7.4V 5000mah lipos @ 35c for $5 each?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
