Lipo's 2s2p vs. 2s1p
  • sjslhill
    • 1563
    #46
    You don't need a tap on all of them if the pack was made correctly.....2 cells share one tap and they will always be the same voltage and charge the same.
    • ice329
      • 797
      #47
      Hi steve that was a question I had... would the two tied together balance themselves out. If you say yes then the 3 wire tap is good.
      • sjslhill
        • 1563
        #48
        Yes, the two cells will balance out and can never get too far out unless a cell goes bad.
        • ice329
          • 797
          #49
          Then were good...
          • slickxxx
            • Jan 2009
            • 1
            #50
            Can someone tell me if it's safe to connect two 2s1p team orion packs to make 2s2p. The packs that I have are 3200mah team orion race spec carbons. The packs use 4mm bullet connectors and I would like them to connect to one deans. If this is alright, can someone tell me what the connector I should make will look like? Should I run both posatives to the posative on the deans and the negatives to the negative?
            • Tunda
              Eh no steal my slipa
              • 844
              #51
              hey guys i saw on cheapbatteries . com they have some 5000mah 7.4v 1 cell are they any good?
              Hawaiian Tunda
              • Meniscus
                Refuse the box exists!
                • 3312
                #52
                Do you have a link? I did a quick sweep of the website and did not see the items you are referring to.
                • Tunda
                  • 844
                  #53
                  sorry i went backed and checked and i must of read it wrong...................
                  Hawaiian Tunda
                  • Meniscus
                    • 3312
                    #54
                    LOL, no stress. Are you having dreams again of 7.4V 5000mah lipos @ 35c for $5 each?
                    • Tunda
                      • 844
                      #55
                      I guess???????????????????????????/
                      Hawaiian Tunda
