HiModel 4s-8s 200 amp esc
  • rockwerks
    • Jul 2008
    • 772
    #211
    I found the two-part thermal epoxy to work great
    which epoxy? what brand?
    an RC rock crawler lost in a sea of boat parts.........
    • questtek
      • 648
      #212
      You can see the pics attached. The cure time is about 24 hrs room temp but you can boost it to just an hour or two if you elevate the temp. I provide more details in my thread on ESC cooling in the FE questions and answers forum.
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1743
        #213
        I tried to skim through all the pages and still wondering if you could waterproof with liquid electrical tape. It's not conductive. What's your thoughts about this?
        • Jeff Wohlt
          • 2740
          #214
          That stuff should work fine. The problem I see is will will hold heat in.
          Still should be fine the epxoy 270 is about the same...anything on them will hold some heat in but keeping fets cool is the key.
          I even thought of just spray undercoating in the auto section but not sure the stuff will eat anything without testing on something first.
          www.rcraceboat.com
          jwohlt5362@yahoo.com
          • rockwerks
            • Jul 2008
            • 772
            #215
            spray on truck bed liner
            • Jeff Wohlt
              • 2740
              #216
              Yes but it has little particles in it...sand or soemthing but it would be nice to be able to drop a brick on it and have it still run
              www.rcraceboat.com
              • questtek
                • 648
                #217
                I would think twice about using liquid electrical tape. The purpose is to provide insulation. It does a great job with electrical insulation. Thermal properties may be a different story. If I were to design a product like liquid electrical tape I would wat it to have good thermal isolation properties also. Remember, copper wires(or any wire for that matter) heats up when current passes thru them so for this application thermal insulation would be a design feature plus.
                You could do some tests on it, but the recommendation to use a 2-part epoxy that was designed specifically for electrical isolation but good thermal conductivity is what I would stick with. Rubber based products like bed insulator materal would also probably have poor thermal conductiity.
                • Jeff Wohlt
                  • 2740
                  #218
                  Very true. Hereis the make up of 270
                  It is certainly better to use something made for these components.
                  www.rcraceboat.com
                  • Alfa Spirit
                    • 2183
                    #219
                    I made water cooling on my HiModel GX 200 using a 3M Thermally conductive tape
                    This 3M product looks fine. What is the best way to waterproof my ESC ? Thanks
                    • NativePaul
                      Greased Weasel
                      • 2770
                      #220
                      Where do you get the black cooling tube Alpha?
                        • 9481
                        #221
                        you could use vacum line from an auto parts store
                        • Alfa Spirit
                          • 2183
                          #222
                          This is a neoprene tube for gasoline very strong and nice looking, 3mm inside and 6mm outside
                            • 9481
                            #223
                            I'm on my way to try out some auto vacum line since they are two blocks away and use it on my CAT UL-1 for the all black hardware look
                            • ozzie-crawl
                              • Sep 2008
                              • 2943
                              #224
                              usally to water proof the esc some form of conformal coating is used.
                              what i use comes in a spray can, i give it a few coates and let dry in the sun for acouple of hours, then take it out of the sun for about 1 hour this lets it harden. then i sand the conformal coating of the top of the fets and add the cooling plate
                                • 9481
                                #225
                                What about electrical tape spray?
