HiModel 4s-8s 200 amp esc
  • tth
    • Apr 2008
    • 1510
    #181
    I have the 3-7 cell that needs the pistix. My 4-8 cell will work on my Tactic 2.4ghz system.
    Hope this helps.
    • Tony
      • 413
      #182
      Hope this helps.
      Did you use the 3-7 cell with your TacTic system? I have the TowerHobby 2.4ghz, which is same as the TacTic 2.4ghz. Its a good thing i do have the PiStix on hand. I knew it would come handy someday.
      • tth
        • Apr 2008
        • 1510
        #183
        Yes I did try it with the tactic system. All the ESC did was beep it would not arm at all. Plugged in the pistix and it went through the sequence.
        • ksm2001
          • 377
          #184
          Hope this helps.
          That's strange, I have both the 3-7 and 4-8 cell esc's and both work, arm, and program fine using my Spektrum Dx3.0 with no problems and no pistix. But if your going to buy one I would suggest the 4-8 cell JMO.
          Ken
          DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
          • tth
            • Apr 2008
            • 1510
            #185
            I definately agree with Ken. Go with the 4-8 cell controller. It runs cooler than my 3-7 for some reson???
            • Tony
              • 413
              #186
              I bought the 3-7 because i didn't want to use the internal BEC. But, if and when this one craps out. I'll get the 4-8cell.
              BTW, the 3-7 cell doesn't have a BEC, but it comes with the red wire. Why is that?
              Can someone please tell me how much amp i'm getting with this setup.
              ESC Himodel 200amp 3-7 cell .
              KB45-08XL 1600kv motor
              prop x445
              6S1P Lipo
              • Rumdog
                • 6453
                #187
                Leave the red wire in on the non bec esc's.
                • Jesse J
                  scale FE enthusiast
                  • 7241
                  #188
                  Reread this whole thread, and still need to ask my question:
                  Anybody know how to get the Himodel 200A noBEC controller to get OUT of programming mode?
                  Dad was running his vegas with the Tower Tactic radio on 4S packs and an 8XL with X640 prop (same as mine which hit 55mph) and his motor was not fully revving (maybe 30mph). So, I thought we should reprogram and heat up his timing (factory setting was 1deg).
                  So after learning the hierarchy of beeps, we got it programmed, but at the end where it says to "swiftly open throttle" it starts again at the first menu. I tried all I could think of and haven't gotten it to come out of programming mode. We can get it to work only AS IF it needed a Pistix (full reverse being neutral and any amount of movement on the trigger being forward).
                  Anybody have the secret? Repeat, the ESC was working normally before, just not winding up the motor. Thanks, J
                  "Look good doin' it"
                  See the fleet
                  • 785boats
                    Wet Track Racing
                    • 3169
                    #189
                    It's been a while since I've reprogrammed one, but I think that after 'Swiftly' opening the throttle, You then have to go to fully closed (brake position) & hold it there until you hear the 'Security beep' then release. Then the unit is good to go.
                    Note; by 'swiftly ' they mean move the throttle to the open position & let it go almost immediately, before you hear the security beep, otherwise it goes back into programme mode. As you have found.
                    So it's;
                    Pull the trigger then let it go before you hear the security beep.
                    Wait a couple of seconds.
                    Full brake & hold until you do hear the security beep.
                    Let go.
                    System is ready.
                    All the best.
                    Paul.
                    • Jesse J
                      scale FE enthusiast
                      • 7241
                      #190
                      Sweet, thanks. Will try and report back. I must have done almost everything BUT that series of tricks.
                      thanks again
                      J
                      See the fleet
                      • Alfa Spirit
                        • 2131
                        #191
                        I just bought HiModel GX 200 Opto no BEC and the manual for this model is different than GX 200 with BEC
                        GX 200 no BEC : http://www.himodel.com/en/rc_manuals_url.php?id=130
                        GX 200 with BEC : http://www.himodel.com/en/rc_manuals_url.php?id=181
                        Which one is correct ?
                        • Jesse J
                          scale FE enthusiast
                          • 7241
                          #192
                          Freakin weird. Plugged her back in and whizzzzzzzzzz . just needed time to think about it.
                          See the fleet
                          • ksm2001
                            • 377
                            #193
                            I took a look at both and from what I read its the GX 200 No BEC, it mentions it in the first part of the manual that this ESC does not have a BEC circuit. The other manual mentions that it has a BEC circuit.
                            Ken
                              • 9479
                              #194
                              Ok, how does one get more timming out of these escs?
                              my MM 9XL motor sounds slow..
                              • motohead417
                                • 91
                                #195
                                hey guys
                                i have a question i was hopeing you guys could help me with, would i be able to mask off the fet's on my esc, apply waterproofing material and then remove tape instead of sanding?
