8s Rigger Build?
  • blackout
    • 10
    8s Rigger Build?
    Was thinking of a single motor 8s rigger build using a modded Zippkit Twin 45 hull. Was looking at the TP 40" x 100" motor, 1090 kv. But I was wondering whether I should go up to their 56" x 92" motor, 888 kv? Any thoughts? I'm looking to do 70 mph on a 1 mile course. (Heat race boat.) Total mah would be 5,000. (Two 4s packs in series.) Thanks.
  • T.S.Davis
    • 6228
    You'll want more kv for 8s than 888. I do like the 56 series motors because they are 6 pole but I don't have experience with them on 8s. I might have a Neu 2217 around 1050kv if you're interested. I'll check when I get home.
    Noisy person
      • 7990
      What class will the OP be racing? What other boats will he be racing against, gas/nitro/FE? Is he looking for a heat average of 70 mph or a 70 mph top speed?
      The JAE riggers are easy to push, no need for a heavy 56 mm motor. Somehow, 4-pole motors win races and set records all the time. A good quality 40x100-ish motor with a Kv around 1100/1200 will work great. A top speed of 70 is easy-peazy for 8S (example, my JAE does upper 70s on 4S on the oval with a little 1415 motor averaging under 120 amps). For that performance he probably won’t need the weight of 5000 mAh either.
      • HTVboats
        • 802
        I used a 45 JAE with a TP 40X92(4060) 1050kv on 8S with an X452 and ran low 70's. Still a work in progress on the back burner with other priority projects. I would not go to a 56mm motor because of weight. The 40mm has all the power you can handle.
        Mic
        Mic Halbrehder
        IMPBA 8656
        NAMBA 1414
        • T.S.Davis
          • 6228
          I would take these guys opinions on it over my own. They're put'n them on the water. My thinking is mere speculation as I haven't.
          Noisy person
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            All looks good except the 5000 mah. Thats a little on the low side. Better to go 6000+
              • 7990
              Mark, he only wants 70 mph.......
              • blackout
                • 10
                I probably will be racing in open rigger/hydro with gas and big block nitro at the club level. I'm not looking for a serious race boat, but mostly a fun boat that will finish a race if I decide to take it racing.
                • RaceMechaniX
                  • 2825
                  A little extra weight will not hurt in the open class. Yes, it will require a little more power to push but it will be more likely to finish.
                  The TP 56 series are a good choice as you can swing a decent size prop which helps with choppy race water.
                  I have a TP5670 motor in a 8S1P SGX rigger which runs around 72-75mph. I can also run it on 6S swinging gas size props.
                  However the TP 56 series are big compared to the standard 40mm motors. A lot will depend on how a motor fits in the hull. The JAE twin nitro hulls are pretty compact and may be challenging to fit large diameter motors.
                  You will need a decent 200A 8S ESC and that may be the hardest challenge.
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
                  • blackout
                    • 10
                    [ATTACH=CONFIG]165752[/ATTACH]
                    What about this for a speed control? Thanks for the info!
                    https://www.offshoreelectrics.com/pr...d=hef-HBX1200L
                    • MarkF
                      dinogylipos.com
                      • Mar 2008
                      • 979
                      That's a good esc.
                      • rol243
                        • Apr 2017
                        • 1038
                        Fluid, you do mean 1450 prop i hope not 1415. also did you find the 1450 better than the H7 ?
                        • StevenBryant
                          • Nov 2012
                          • 359
                          1415 is a motor from NUE
                          Sent from my iPad using Tapatalk
                            • 7990
                            The 1415 is a Castle motor with a Kv of 2400, more than enough to push the little rigger very fast. The Octura 1450 is a high lift prop and not very suitable for a JAE without detonguing and cupping. I find the H-7 slightly cupped to be a very good fit for this setup, but if I was starting over I would go for one of the newer ABC 17* rake props. They are more efficient and don’t require any modification to run great.
                            • eric113
                              • Sep 2011
                              • 327
                              Jay, so ABC 1716 prop for 4s oval heat racing?
