Does anyone use AAA's for BEC?
  • jwt
    jwt
    • 66
    ubec rules
    Originally posted by Jimmy Sterling View Post
    Why not just run a BEC module ,less weight and it will supply a far better regulated voltage then what a Rx pack would.
    You also dont have to recharge or replace it after so many runs, I run BEC in all my boats and have never had an issue. Is there a reason why so may people dont use it ?
    Jimmy
    here here - i could not say it better...
    this one works for me.
    tms
    • sjslhill
      • 1563
      AAA Enloops are Sanyo NIMH cells that hold the charge, many use these now in aircraft. I use AAA and AA in all the kids toys and they are excellent.
      • sjslhill
        • 1563
        For larger boats one might consider running 2, A123 or K2 18650 LiFEPO4 cell. These cells do not lose their charge either.
        • Jimmy Sterling
          • Apr 2008
          • 417
          But why bother running an external Rx pack
          Come to the FASST side
          • Simon.O.
            • 1611
            BEC, UBEC, Rx packs.........this has been gone over and nearly qualifies as an deceased equine.
            3A's or AAA's will be fine for an Rx pack for a given application.
            When I began my research into this subject I did some bench tests to determine my current draw and requirements.
            I have no BEC out from my speedy so an Rx pack or UBEC is has to be.
            I now run a square 9V cell in 3 of my hulls due to limited space and a 4xAA pack in 2 others as they can cope with the weight penalty.
            To be honest I would use BEC if it were there and then use a UBEC as a second choice.
            An Rx pack needs to be checked for power and trusted.
            The answer to your question is this.
            If 4 (5 is better) AAA cells will meet your power requirements and fit in the hull then go for it.
            I have done a LOT of reading on the subject so do not be afraid to ask more.
            We are all here to help each other with our boats.
            • Meniscus
              Refuse the box exists!
              • 3312
              For a ESC that I am using, I'm looking at exceeding the recommended voltage and continue to use BEC. With regards to UBEC, I'm mildly concerned about current draw for a servo that is a little overkill for the boat in use. So, I figured I'd slide an RX pack in there and be done. Curiosity got the better of me and I was wondering what others use or have used in the past.
              So that's the reasoning behind why I was thinking rx pack. I may consider the UBEC, but I don't run those fancy/expensive lipos that some of you guys run!
              • 785boats
                Wet Track Racing
                • 3423
                I'm with you on this Jimmy.
                Why use batteries at all ?
                In all my boats (about 25 at last count) both FE & scale, brushed & brushless, metals & lipo, I've never used them.
                If the ESC has BEC, I use it. If I'm going to exceed the recommended voltage for that BEC I'll disconnect it & use a UBEC.
                If the ESC has no BEC then the UBEC is the obvious choice to me.
                Never had a problem.
                Meniscus.
                I see your concern with a servo with a higher current draw but these UBECs have a current rating of 3A & can be switched to 6V for better efficiency. Input voltage is up to 42V. That will handle any servo you are likely to use .
                There are many others on the market but that's the one I use.
                All the best.
                Paul.
                • Meniscus
                  • 3312
                  Good info! Since I'm a rather new boater, I haven't used very much in the way of UBEC myself. I may have to try for myself!
                  • Simon.O.
                    • 1611
                    I know I am famous for draging up old threads !
                    Can anyone tell me why I should use 6v instead of 4.8v for Rx power.
                    This is for my latest rigger and I will be using Nimh AAA cells of 900mAh.
                    Space and weight are not the biggest issue ( Servo speed and strength has been tested on 4.8 and pans out fine for my needs )
                    I want to know if anyone has a good reason why 4.8v is not the go.
                    If not then I will use 4.8v for this project.
                    Bear in mind that I do use 9v square cells for my small 2S powered boats.
                    • EPower
                      • 417
                      Hi Simon i have always used 6v 2700 Mah packs for my RX but then i come from gas boating background where we use 1/4 scale servos and need as much grunt as possible For your application i'm sure that 4.8v would be fine
                      Adrian
                      • Meniscus
                        • 3312
                        Simon, this is funny. Earlier in the week, I picked up a AAA battery holder and decided to put the appropriate connectors on it to eliminate using a BEC on one of my ESC's. I'm planning on running those disposable lithium batts because they don't seem to 'dump' under load and are lighter weight than the NiMH I have sitting around.
                        I was actually going to try today if I get to soldering the connector on with the other stuff I have to do.
                        • Jeff Wohlt
                          • 2740
                          I have used 9v cells forever....never a problem. Probably will go to the ubec.
                          I do like the rechargable AAA 5 each and stacked 3/2 and sealed. Thought about a cell phone battery and using the cell phone charger since I have several but not sure how it would work.
                          www.rcraceboat.com
                          jwohlt5362@yahoo.com
                          • H2OCamel
                            FAST ELECTRIC EVERYTHING
                            • 494
                            I have been using voltage regulators ($3 at my LHS) with my 2100mAh sized lipos from my planes to power my hpr-115. I have droped down to the 700mAh From my e-flight blade cx They are cheap and I know they hold their charge and fit in everything I own. I used to use the AAA rapid recharcables (15min recharge time) in the battery holder but swithched after having the bateries pop out and twice the plastic broke on the holder. I still use the rapid rechargeables in my tx's they are 4yrs old and still going strong saving me tons of $$ in AAA's
                            Meniscus I have a brand new CC BEC if you want to try it it is very small and compact
                            http://www.offshoreelectrics.com/pro...tle-bec&cat=75
                            "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                            • Meniscus
                              • 3312
                              Sure, I'll try it. My main problem is when it comes to a few rigger builds. There's just so little room and I'd hate to make the tub that much larger to accommodate.
                              PM me a price plus shipping to 23320.
                              Thanks! I've never tried one myself to be honest. I used to run hovercrafts back in the 90's and did something similar then, but it was just a voltage regulator and archaic at that! LOL!
                              • bwells
                                • Jan 2009
                                • 847
                                OKAY I give , what does UBEC stand for versus BEC ( batt eliminating circuit). I like the TURNIGY one and my new esc is opto but I don't what the hassle of more batteries. Thanks
