Does anyone use AAA's for BEC?
  • Meniscus
    Refuse the box exists!
    • 3312
    Just like the title, does anyone use AAA's for BEC?
  • Steven Vaccaro
    Administrator
    • 8934
    I use AA in most my setups. I dont see why AAA will not work.
    Steven Vaccaro
    • ghostofpf1
      • 399
      Just an FYI..."BEC" stands for "Battery Elimination Circuit" and using pencells is perfectly fine for powering rx and servos but technically is not using a "BEC"
      hope this illuminates
      Ghost
      • Meniscus
        • 3312
        I know I know
        You got the concept though!
        • GregS
          • 82
          I use either AA or AAA for powering my receivers and servos. No problem with either.
          Greg
          • Meniscus
            • 3312
            Thanks for the feedback. Hopefully I'll have space for the AAA's, LOL.
            • Diegoboy
              • Mar 2007
              • 7444
              Why not try AAAA batteries if space is a concern?
              AAA = 44.5 mm in length and 10.5 mm in diameter
              AAAA = 42.5 mm long and 8.3 mm in diameter
              • Meniscus
                • 3312
                I am not familiar with the mah capacities for AAAA batts. Do they make nimh rechargables with higher mah?
                • GregS
                  • 82
                  I just buy alkalines. You can buy Duracells and Energizers in large quantities from the big stores for very little. It's a lot cheaper than using rechargeables and you don't have the hassle of having to charge them. Also I believe there's a greater chance of losing control of a model with rechargeables as they tend to die very suddenly rather than gradually.
                  I'm not familiar with AAAA batteries. The AAA Duracell alkalines I use in my receiver packs last a very long time.
                  Greg
                  • detox
                    • 2357
                    One 9 volt battery has six AAAA cells hidden inside.
                    • Flying Scotsman
                      Fast Electric Adict!
                      • 5195
                      I use Ni-Mh rechargeable 5 cell packs...why....better for the enviroment....less weight...a better electrical contact than a cheap AA 4 cell holder. Li-po is also a good choice with a voltage limiting device for 2S
                      Douggie
                      • detox
                        • 2357
                        NIMH packs require cycling during off season. So I like NICD packs for receiver use...no cycling.
                        http://www3.towerhobbies.com/cgi-bin...?&I=LXHUA8&P=7
                        • GregS
                          • 82
                          That's a good point. I had a battery pop out of the holder from rough water during a race. My boat stopped and I was later hit by another boat as well.
                          Greg
                          • Meniscus
                            • 3312
                            I'm glad someone is thinking about the environment.
                            (while I'm letting the fumes from Corrosion X dissipate outside) LOL!
                            • Jimmy Sterling
                              • Apr 2008
                              • 417
                              Why not just run a BEC module ,less weight and it will supply a far better regulated voltage then what a Rx pack would.
                              You also dont have to recharge or replace it after so many runs, I run BEC in all my boats and have never had an issue. Is there a reason why so may people dont use it ?
                              Come to the FASST side
