Shaft seal / Stuffing tube?
  • mnm99
    • Aug 2016
    • 48
    I know it's been said 1000 times, and I've read with or without for hours. My question is with the shaft seal. What would be the best option for running in salt water? I found this and was wondering if it would be better/easier for me. Pros and cons?
    https://www.offshoreelectrics.com/pr...d=aero-sts-125
  • NativePaul
    Greased Weasel
    • 2770
    I wonder if it works any better than the usual piece of silicone or heat shrink tube over the end of the stuffing tube.
    • Peter A
      • 1622
      Best seal for keeping water out - grease.
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        The problem(s) I found when I was sent the shaft seal to evaluate are : (and this would assume that your shaft gets removed for drying and re-lubing after each immersion - especially in your case with salt water)
        To release the shaft for maintenance and then re-install it you must loosen, then re-tighten the hex set (grub) screw. First off, anyone with experience with these pesky little critters will tell you that they will ultimately strip (or if left with salt water on them) become impossible to release, making your shaft a permanent fixture on your boat. You don't want that to happen.
        Secondly, if you do the right thing and pull your shaft after each use and somehow avoid kerfuffling the hex, remember that each time you re-tighten it you are eating yet another indentation in your flex. Eventually it will weaken and break from being chewed on.
        Here's my recommendation :
        Pull the flex after each run
        Flog it on a hard surface to expel any saltwater that permeated the coils (the gas guys beat their .250 cables mercifully - I see this all the time)
        squirt some WD40 on it to chase any residual moisture, smear with grease and wrap in paper towel and store for future use
        I use a mixture of Harley Synthetic 20-50W thinned by Marvel Mystery Oil to lube before a race - your choice may vary
        Like Peter said, shove some grease into the stuffing tube after storing the wrapped up shaft to minimize water intrusion
        I use this, just perfect for that:
        https://www.offshoreelectrics.com/pr...od=hh-dyne4200
        (remember to flush your cooling lines too !)
        • mnm99
          • Aug 2016
          • 48
          Well, I got the Sonicwake today. I pulled the shaft out and there's no sleeve. Or is there?? I going to use extreme grease from my real boat.
          • 30nitro
            • Feb 2018
            • 330
            https://www.marineengineparts.com/me...se-8-oz-bottle
            There should be a liner in there...mine had one... And yeah...extreme grease should work fine....... like you...i use it on my mercruiser out drive.....
            • mnm99
              • Aug 2016
              • 48
              I use to on my Mercruiser. I now have twin 496 Big block V-drives...LOL....
