One motor vs. two motors
  • Nevs
    Sven
    • Sep 2011
    • 165
    There are realy no arguments against a twin setup ?.
    None in this thread....
    • StevenBryant
      • Nov 2012
      • 366
      Twice the cost......
      Sent from my iPad using Tapatalk
      • Mad Hatter
        • Aug 2018
        • 64
        Twice the weight......
        • Nevs
          Sven
          • Sep 2011
          • 165
          Its boring... The boat most likely runs perfect the first time you run it..
          • Nevs
            Sven
            • Sep 2011
            • 165
            I dont know about the weight and cost.
            A TP 5870 cost 296 Eu and weigh 1274 G
            2xTP 4070 cost 270 Eu and weigh 1250 G
            And aprox. the same power.
              My theory always was that you could run two lesser motors to attain the same task as one big motor. Or more in my case these days, you can run two of the same motor and turn bigger props than you could with the one motor
              • Nevs
                Sven
                • Sep 2011
                • 165
                I imagine a 45-50 inch mono with a tp 5850-70 and 10-12s 1p(2p) 5-8000 mAh..A twin setup with that would be impossible ?.I think you very easily run into "weight-problems" if you try to get more watts out of a twin setup compared to a "Max" single setup.
                  Well this is a 40” mono with twin TP 4030’s on 8s 44-4800mah 2p. It’s not really fast but I can get 9-10 mins runtime with 442’s.
                  I don’t see why something bigger wouldn’t be possible with twin 4050 or 4060’s
                  • Mad Hatter
                    • Aug 2018
                    • 64
                    I was told (years ago), by a mercury tech that a single 300 hp outboard can outperform a pair of 200 hp outboards on an an equal boat. I don't know how true this is but it does lose the effect of counter rotation.
                    • Nevs
                      Sven
                      • Sep 2011
                      • 165
                      According to this video 2x150 hp outperforms 1x300 hp. Even if the setup would be around 400 pounds heavier.
                      Single: 49,1 mph
                      Twin: 50,5 mph
                      0-30 mph
                      Single: 5,87 sec
                      Twin: 5,03 sec.
                      • rearwheelin
                        • 2101
                        43” Aeromarine Conquest quad drive , 4 1515’s , 4 T180’s , 4s 4p 20,000mah , 447 left and right props. 17 lbs RTR on 4s, 22 lbs on 6s with 20,000mah.... way more efficient than a large single engine and at the time I built this boat the 4 separate power systems was less money than 10,000 watt single prop setup . The quad was a incredible fun runner to say the least . Running on 4s in this video with half finished 447’s. Much cooler that a single IMHO
                        --Albert Einstein
                        • rearwheelin
                          • 2101
                          Singles outperform threw the turns , that’s it
                          --Albert Einstein
                          • rearwheelin
                            • 2101
                            Not always
                            --Albert Einstein
                            • Nevs
                              Sven
                              • Sep 2011
                              • 165
                              Hi. Fun boat project with 4 engines.. Im not sure if a single outperforms a twin in turns. In a cat. Yes. in a mono . Yes. If you have outward rotating props. With inward rotating props there might not be any significant difference.. But never tried inward rotation so I do not know.
