There are realy no arguments against a twin setup ?.
One motor vs. two motors
Well this is a 40” mono with twin TP 4030’s on 8s 44-4800mah 2p. It’s not really fast but I can get 9-10 mins runtime with 442’s.
I don’t see why something bigger wouldn’t be possible with twin 4050 or 4060’s
I was told (years ago), by a mercury tech that a single 300 hp outboard can outperform a pair of 200 hp outboards on an an equal boat. I don't know how true this is but it does lose the effect of counter rotation.
According to this video 2x150 hp outperforms 1x300 hp. Even if the setup would be around 400 pounds heavier.
Single: 49,1 mph
Twin: 50,5 mph
0-30 mph
Single: 5,87 sec
Twin: 5,03 sec.
43” Aeromarine Conquest quad drive , 4 1515’s , 4 T180’s , 4s 4p 20,000mah , 447 left and right props. 17 lbs RTR on 4s, 22 lbs on 6s with 20,000mah.... way more efficient than a large single engine and at the time I built this boat the 4 separate power systems was less money than 10,000 watt single prop setup . The quad was a incredible fun runner to say the least . Running on 4s in this video with half finished 447’s. Much cooler that a single IMHO
--Albert Einstein
Singles outperform threw the turns , that’s itOriginally posted by Mad Hatter View PostI was told (years ago), by a mercury tech that a single 300 hp outboard can outperform a pair of 200 hp outboards on an an equal boat. I don't know how true this is but it does lose the effect of counter rotation."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Hi. Fun boat project with 4 engines.. Im not sure if a single outperforms a twin in turns. In a cat. Yes. in a mono . Yes. If you have outward rotating props. With inward rotating props there might not be any significant difference.. But never tried inward rotation so I do not know.
