JAE 33FE Electric Outrigger Help
  • don ferrette
    • 1252
    Originally posted by rol243 View Post
    I run a Het 40mm x 2250 kv motor in my jae 33 on 4s with a 6000 mah pack, after 1 mill lap and 5 race laps the remaining capacity is at around 50% . taking into account the Het Typhoon motor is very efficient.
    50%??? What prop and ESC? I tried both a Castle 1515 and now a TP 3650 at 4S and 5000mah was good for 1 mill lap and about 5 "race" laps then pack was just under 20%.
    - IMPBA Hall of Fame -
    - IMPBA Hydro Technical Director -
    • rol243
      • Apr 2017
      • 1038
      prop is a slightly back cut and tip cupped H7, 180 Turnigy v3 esc. hrb 6000 - 4s. esc and pack only slightly warm if that. i did start off with a castle 1414 -2400 kv motor but this just drained battery power plus made battery pack too warm as well as a t.p. 3650- 2310 kv motor same issues until i tried the Het..
      • jim82
        • Jan 2013
        • 1358
        Neu coolers fit the Het motors?
        • rol243
          • Apr 2017
          • 1038
          Thanks Jim, yes I did have trouble finding a suitable sized cooling can o rings for this motor as there no the exact 40mm diameter same as there 36 mm can is not really 36mm in diameter. RC Boat Bitz have the suitable sizes I found.
          • jim82
            • Jan 2013
            • 1358
            That's why I haven't picked one up yet because I did'nt know what cooler would work but i think i read somewhere the Neu coolers will fit. I have one on the way i just need to order the motor
            • ezhitz
              • Aug 2009
              • 466
              I built one the end of last summer running TP 4060 1650kv on a single 6S 4500 mah limited testing it was a lot of fun to drive. I did lower the battery tray and raised the lid so the lipo would fit.
              :canada
              • rol243
                • Apr 2017
                • 1038
                looks nice and bright also like the matching stand colours.
                • rol243
                  • Apr 2017
                  • 1038
                  Jim, the normal 36 or 40 mm cooling can sizes are fine for both sized motors its just the o-ring size you need to get right.
                  • RC boat addict
                    • May 2020
                    • 61
                    Ezhitz,
                    I can?t view the thumbnails for some reason. I have this exact motor and a 200 amp ZTW seal esc I made my own rigger and I can?t get it to handle so I would love to see your set up and videos of it running if you have any.
                    What speed are you achieving ?
                    • RC boat addict
                      • May 2020
                      • 61
                      Hey Raydee, I have that same motor It?s such a heavy big and powerful motor I thought the 33 might not be big enough so I built my own 36 inch rigger with bigger more buoyant sponsons much like the European p6 6s riggers but I can?t get it to handle. I am looking ahead and may have to buy either a ML boat works RSX 380 or the JRE 33 or zipkits 33. Do you have video and or photos I can view somewhere and also what speed are you achieving ?
                      Regards James
                      Last edited by RC boat addict; 07-27-2020, 05:15 PM. Reason: The word botany should be buoyant
                      • Turbostang434
                        • Dec 2021
                        • 12
                        I have a JAE 33. TP 4050 2100kv on 6s. 150a ESC. My boat runs in the 90s. Mph. H7 prop. Few more tweaks and I'll break 100mph.
                        • RC boat addict
                          • May 2020
                          • 61
                          Since starting this post I built a 33 Fe as well I am running a 4060 1650 kv tp I have tried H7 it?s too slow probably my motors kv. The fastest speed was 1819 abc but only 79 mph 78 with 1817 having said that mine is quite heavy I am running a 200 amp Ztw esc it?s heavy the motor is heavy and my 5000mah 100 c Yowoo graphene 6s lipo is also heavy.
                          I would love to know your exact set up and settings.
                          • HTVboats
                            • 936
                            We have a few locals who run a Q / limited class with a 4074 motor limit and a bunch of JAE 3's. With a 1750kv Lepoard and 5000ma I run a 1817/3 ABC cut down to basically a 1717 and run 6 laps in heats at 65-67mph. Doesn't sound too fast but I can pin the throttle and never lift in traffic. (till I hit a bouy) Good fun racing and a $50 Flycolor esc. I am sure with a flat out prop min 70's possible
                            Mic
                            Mic Halbrehder
                            IMPBA 8656
                            NAMBA 1414
                            • Turbostang434
                              • Dec 2021
                              • 12
                              I'm running a Flycolor 150a ESC. With a extra cap pack I made. CNHL 5200or 6200 90c lipo with 8mm connectors for everything. H7 prop from Chris at Dasabota. I also have been getting help from Joe at zippkits. That 4060 is heavy. I'm running. 03 down on the turn fin.
                              • HTVboats
                                • 936
                                I see your in Florida. There is a one day FE race in Brandon March 27th so come out and see what were doing. Enter if you like we could use some full Q hydro's and anything else you have
                                Mic
                                Mic Halbrehder
                                IMPBA 8656
                                NAMBA 1414
