Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 JAE 33FE Electric Outrigger Help - RcBoaters Forum
  • KMUDD
    • Sep 2017
    • 3
    I am putting together a zippkits JAE 33FE Electric Outrigger and am needing recommendations for motor, esc, batteries & prop. I know nothing about electric stuff lol, i'm a nitro guy. I'm not looking to run p-limited rules, I want something hot and fast. any suggestions would be appreciated.
  • jim82
    • Jan 2013
    • 1358
    Depends on if you want to run 4s or 6s
    • KMUDD
      • Sep 2017
      • 3
      i'm thinking a hot 4s should be enough
      • rol243
        • Apr 2017
        • 1038
        a hot 4s set up would be something like a 40mm dia x 2400 kv motor / 220 amp esc / abc H7 prop / 6000 mah -4s lipo. this rigger can take a 6s power set up which will be faster than the 4s set up.
        • jim82
          • Jan 2013
          • 1358
          Tp 4050 2100kv motor, Castle xlx ESC converted to water cooling, 4s 5000mah turnigy panther lipo, and an abc 2015-17-45 prop will get around 70mph
          • Nevs
            Sven
            • Sep 2011
            • 165
            It could be fun to see it as a twin setup, (would not recommend it), with a pair of small in- / outrunners.
            And then 2xcheap 120 esc and one 4s/6000/60c+ lipo...
            • Nevs
              Sven
              • Sep 2011
              • 165
              The props would probably have to be something very small. In the 30 mm range.
              • KMUDD
                • Sep 2017
                • 3
                I didn't realize it would handle a 6s. I would rather go with that. Any suggestions for that.
                • jim82
                  • Jan 2013
                  • 1358
                  Go down in kv to around 1500 and choose a 6s lipo that will fit.
                  • Raydee
                    • 1619
                    Mine runs great with a TP 4060 1650 kv motor and a ABC H7 prop on 6s. I wouldn't go back to 4s on this boat, it's right at home on 6s.
                    Sent from my SM-N950U using Tapatalk
                    Team Liquid Dash
                    • jim82
                      • Jan 2013
                      • 1358
                      Plenty enough power on 4s with the right props
                      • HTVboats
                        • Jun 2011
                        • 936
                        Keep in mind going to 6S does not mean you need to put a huge motor in the boat. A 1400-1600kv 36 or 40mm by 74mm will work well and allow you to use a controller like the OSE raider150 (Flycolor150) as amps go down as voltage goes up. I recently bought a Turnigy 36X74 1600 and it performs better than I expected on a 32" tunnel with a Fly150 on 6S. Less than $100 motor and ESC together. A little less hp makes setup and handling easier.
                        Mic
                        Mic Halbrehder
                        IMPBA 8656
                        NAMBA 1414
                        • don ferrette
                          • 1252
                          Mic
                          You may also see with the higher voltage/lower amp of the 6S set up that the mah requirement might go down. My 10S rigger was ballistic and got it done easily on 5000mah total yet the 4S rigger I'm setting up for a friend came up short at 5000 of total needed run time.
                          - IMPBA Hall of Fame -
                          - IMPBA Hydro Technical Director -
                          • jim82
                            • Jan 2013
                            • 1358
                            What motor?
                            • rol243
                              • Apr 2017
                              • 1038
                              I run a Het 40mm x 2250 kv motor in my jae 33 on 4s with a 6000 mah pack, after 1 mill lap and 5 race laps the remaining capacity is at around 50% . taking into account the Het Typhoon motor is very efficient.
