will this combo work out mathmaticaly
  • Crash
    • Oct 2015
    • 313
    36 inch mono FG
    tp power 4060 3y 1750kv(3200watts continuos, 6200 maxwatts)
    seaking 180 v3
    2 3s 6000mah 50c 100 burst
    thanks guys, I am a Newbee to FE
  • StevenBryant
    • Nov 2012
    • 366
    You KV seems very low for a 3s setup, I almost use that kv for my 6s.
    For mono I use the following KV:
    2s = 5000kv
    3s = 3400kv
    4s = 2600kv
    6s = 1600kv
    • Crash
      • Oct 2015
      • 313
      Yes you're right I meant 6's
      • StevenBryant
        • Nov 2012
        • 366
        Your continuous amp draw is rated at 144 amps which for me is a little to close for comfort for my liking with a 180 amp esc, I would run a higher amp esc just to be sure.
        • TRUCKPULL
          • 3293
          High KV for 6S in a Mono ( Small Prop)
          I use 1850kv on 4S2P in my Mono
          1750kv - I would say 5S would be better
          Unless you are only going to make a couple of speed runs each time out.
          Larry
          • Crash
            • Oct 2015
            • 313
            I already own this set up and the test runs going not so good. I can run about half throttle ok but when I try to go full throttle the ESC goes to half power until I bring boat in and reset the esc. It does this stone cold and hot around 160F
            should I suspect ESC is too small or is it possible My lipos are not up to the motor has to draw out of them?
            • Crash
              • Oct 2015
              • 313
              thank you
              • Crash
                • Oct 2015
                • 313
                Larry
                thank you
                • StevenBryant
                  • Nov 2012
                  • 366
                  No probs mate, my Q mono runs a 1717 castle motor 1580kv with a watercooled castle XL2 esc.
                  • Crash
                    • Oct 2015
                    • 313
                    200 amp esc be enough?
                    • StevenBryant
                      • Nov 2012
                      • 366
                      The 180 amp will work but does not leave much head room if you over prop the boat. I personally like to have plenty of room so I’m not pushing the esc too hard.
                      • Crash
                        • Oct 2015
                        • 313
                        the esc is shutting down at full throttle....
                        • martin
                          • 2881
                          What do you have the lvc set @, you could try lowering the lvc or turning the lvc off & see if that makes a difference. With the lvc turned off you must time your run time so as not to over discharge the batteries, it also depends on how good your batteries are with not to much voltage drop under load.
                          • martin
                            • 2881
                            Their have also been known problems with some of the 180a esc in the past shutting down like this, it was talked about on this forum a while back even with the lvc turned off they were still shutting down.
                            • Crash
                              • Oct 2015
                              • 313
                              I am concerned the lipos are not up to par which is tricking the ESC to shut down , like u said
                              they are RGB brand
