Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Fibreglass 1/10 scale drag boat - RcBoaters Forum
  • hughb
    • 152
    Here’s the link for more pics of that V8
    https://forums.offshoreelectrics.com...light=Tenshock
    • Old School
      • Aug 2017
      • 686
      That scratchbuilt motor is very well done. It must have taken you a long time to complete it.
      I decided that the hull needed a little floor strengthening so applied an additional carbon fibre layer to the transom overlapping with the piece added to the floor of the hull, extending up the sides.
      Edit: I found this hull with an offset drive.
      • rol243
        • Apr 2017
        • 1038
        You don,t need the right [ starboard ] offset with the hydros as opposed to mono hulls.
        • Old School
          • Aug 2017
          • 686
          This is a few components of the Dragondarkwings 1/10 scale 3D printed motor. Expensive but amazing. Everything screws together with the word's smallest screws. Includes a full size metal gear servo plus another mini type servo that I assume is for operating the butterflies. No instructions are included but I blieve that there are videos on You-Tube.
          Edit: link to motor on You-Tube
          • hughb
            • 152
            Yeah nice. Looks to be a perfect height as well for the bug catcher to clear the top of the canopy.
            • Old School
              • Aug 2017
              • 686
              There is actually a piece about 1 cm high that goes between the supercharger and the bugcatcher so will raise it a further 1 cm. I had to watch the video to make out what goes where. The metal servo as supplied is simply to strip for the electric motor and control board.
              • Old School
                • Aug 2017
                • 686
                For those with a bit more building experience than I do, when I mount my stuffing tube through the hull I intend bonding the next telescopic size larger diameter tube in the hull passing the stuffing tubing through this and sealing it. Should I resin bond the fixed section of tubing to the stuffing tube or use an RTV sealant, please? Using RTV should allow non-destructive disassembly should the stuffing tube ever need removing. My experience is with stingers and this is my first strut install.
                Edit: found this image
                https://forums.offshoreelectrics.com...chmentid=87104
                • Old School
                  • Aug 2017
                  • 686
                  I do not know how people build small boats as even with this hull I am quickly running out of room. It is like the proverbial 10lb shyte in a 5lb bag. Just mocking up the interior.
                  • rol243
                    • Apr 2017
                    • 1038
                    I think you better check to make sure this hull still floats with that monster lipo inside. that is a small hydro.
                    • Old School
                      • Aug 2017
                      • 686
                      I did a float test previously using two 3300 mah 3s batteries before deciding to go with a single 5s 4000 mah battery.
                      • rol243
                        • Apr 2017
                        • 1038
                        just looking at the actual size of this drag hydro makes me think the power your going to use in this hull will be too much . the beam is quite narrow and having this more than ample power plus no doubt a pitchy prop theres a good chance this hull will roll over just from prop / power torque. I hope i am wrong in my thinkings but she will be touchy on the trigger.
                        • Old School
                          • Aug 2017
                          • 686
                          More POWER, as Jeremy Clarkson likes to say. On a serious side, the motor is most likely a little over the top, but is what I had available. If too much I can go to a 3660. I was actually quite surprised when I saw the hull floating with the two 3s batteries as it seemed rather heavy. However, it did float very well.
                          I do not intend an aggressive prop initially. My son can work on that as the hull shows if it has promise or not. All the setup can be re-used on a bigger hull if needed. At present the hull is 590 mm X 220 mm.
                          • rol243
                            • Apr 2017
                            • 1038
                            with our p rigger 4s hydros which have approx 540mm sponson span , these can flip a sponson if you hit the throttle to hard , this is what makes me think with your hydro hull with a 220mm beam is going to be very hairy unless you open the throttle gradually and not wot at once, so if your wanting a standing start as in drag race , you will lose alot of time with a slow start. a rolling start will be fine though.
                            • rol243
                              • Apr 2017
                              • 1038
                              Drag Boat City . com , has your hydro hull set up and has done 124 mph. take note of strut angle etc plus motor / strut offset.
                              • Old School
                                • Aug 2017
                                • 686
                                Many thanks. I have planned a 6 mm offset.
