Arowana 32" self righting hull
  • Old School
    • Aug 2017
    • 686
    I have purchased two of these hulls (one in my possession, one soon to be intransit) from an eBay seller "thebuild-rc". The build quality looks very good with an immaculate glossy white gelcoat finish, however, I am sure that achieving self righting capabilities will take a lot of experimenting in the bath tub.
    A quick check revealed the chamber leaks inside the hull (probably to be expected as I did intend beefing up the hull). Secondly, the chamber is extremely small occupying no more than about 750 cc. The Arowana 32 is well known for its stability when the hull is inverted in the water due its large flat deck, so I feel that additional lead weight will be needed to be added inside the float chamber towards the rear, plus biasing the battery to the left side.
    I had hoped being a production hull that the flood chamber volume had been sorted out but it seems that I need to do a lot of homework to eventually achieve a self righting hull. Fingers crossed that a new inner wall will not be needed closer to the keel centreline to gain additional volume.
  • rol243
    • Apr 2017
    • 1038
    sounds like a good size 4s class mono hull. any pics of this ?
    • Old School
      • Aug 2017
      • 686
      As requested
      • Old School
        • Aug 2017
        • 686
        Also. Hull is 80 cm in length and 24.5 cm width.
        • rol243
          • Apr 2017
          • 1038
          Thats not a bad looking mono hull atall. wounder if this seller has non self righting hulls available as well.
          • Old School
            • Aug 2017
            • 686
            This is his selection of hulls from his website -
            • boatsrnew2me
              • Oct 2016
              • 474
              i have eyes these hulls before as i love a self righter but i am not a builder . i wasnt aware they sell them on ebay .they do list almost ready to run ones but they are never in stock .
              • Old School
                • Aug 2017
                • 686
                Personally, given that my hull flood chamber leaks I would not trust buying an ATR model. I think that any hull will need rectification plus some fettling to get the hull to self right as the flood chamber is I believe too small a capacity.
                • denboy01
                  • 62
                  Photo shows a Pursuit hull setup for self righting
                  • martin
                    • 2881
                    The Arowana is the same hull bottom as the Pursuit, but with a different deck & hatch.
                    • rayray9
                      Steve Takes My Money
                      • Sep 2016
                      • 98
                      denboy01, does that actually work on the Pursuit?
                      • denboy01
                        • 62
                        The boat in the photo has an almost full length flood chamber and 4oz lead at the c of g between the speedo and battery. With this setup the boat selfrights easily.
                        With heavier speedos and batteries the lead might not be required.
                        • denboy01
                          • 62
                          Youtube has a few examples of Pursuit hulls that self right
                          • rayray9
                            • Sep 2016
                            • 98
                            Any pics of the flood chamber?
                            • denboy01
                              • 62
                              Hi Ray, i'll try and get some more pics on tomorrow
