Motor choice for 6s jae 33
  • rol243
    • Apr 2017
    • 1038
    #61
    Looks like your just about there now Jim, i like the Savox servos too.
    • jim82
      • Jan 2013
      • 1358
      #62
      Have you guys played around with the cog? If so where is best? I'm currently messing around with everything trying to get that sweet spot. So far 62mph on 4s
      • rol243
        • Apr 2017
        • 1038
        #63
        what motor are you running with the 4s set up Jim ? also what type of prop ? I have my 4s pack approx 4 inches in from the transom and the hull seems to ride quite nice. c.o.g. is set around the 60/40 or balanced at the trailing edge of stock turn fin.
        • jim82
          • Jan 2013
          • 1358
          #64
          Did you add weight to the front? I am putting lipo as far forward as I can and cog is near 2in. behind the turn fin. I am running 1515 1y prop is 1450mod prop b/s. I need to work on my H-7 and try it.
          • rol243
            • Apr 2017
            • 1038
            #65
            woops, sorry Jim the cog is just about the same as you have . i was thinking of my jae 21/fe balance point not the jae-33.
            i know these jae,s due to the ski like to be abit tail heavy and don,t like a lifting prop. how does your ride ?
            • jim82
              • Jan 2013
              • 1358
              #66
              Rides good just need some days of no wind to get it right. It has been crazy windy here lately
              • rol243
                • Apr 2017
                • 1038
                #67
                Hows the size of the 12 next to the 33. same length as a 33 sponson.
                • jim82
                  • Jan 2013
                  • 1358
                  #68
                  That is the mini. I been thinking about building a 12 though
                  • jim82
                    • Jan 2013
                    • 1358
                    #69
                    Tried out the H-7 today 65.4mph
                    • rol243
                      • Apr 2017
                      • 1038
                      #70
                      so the H7 is faster than the 1450. is the H7 stock ?
                      • jim82
                        • Jan 2013
                        • 1358
                        #71
                        Stock h7. Going to try this idea out I'm sure someone has tried it before.IMG_20180328_123911546.jpg
                        • rol243
                          • Apr 2017
                          • 1038
                          #72
                          just make sure there are some spring locking washers behind the wing nuts Jim. not sure if i like that idea though.
                          • jim82
                            • Jan 2013
                            • 1358
                            #73
                            Yea once I get everything set right I will probably use regular self locking nuts. Just helps right now to make adjustments faster
                            • jim82
                              • Jan 2013
                              • 1358
                              #74
                              The TP motor that originally had in there was squealing so I had to order some new bearings hopefully that will fix it
                              • rol243
                                • Apr 2017
                                • 1038
                                #75
                                Jim, where you have your turn fin set now [ in pic ] is that about the position of the rear where its going to be left at , or are you still going to try different angles ? the setting now looks like your trying to keep the sponsons wetter , has your hull been riding abit loose in the front ?
