Motor choice for 6s jae 33
  • chevelledude
    • Apr 2017
    • 54
    Almost done building and want choices of setup that would yield 70 to 80 with decent run time. Its for having fun with not racing.Please let me know what would work. Esc- motor-prop. Thanks
    ESC - Raider 150
    Motor - TP 3650/4Y or TP 4050/4Y or Leopard 4074/1650
    Prop - ABC 1915-17* or H-7
    Battery - Minimum 5000 mAh/45C, two 3S/3300 in series would be one option
    There are other options of course, but these will meet your goals.
    • rol243
      • Apr 2017
      • 1038
      is the esc size [ 150 amps ] big enough to handle 6s ?
      • NativePaul
        Greased Weasel
        • 2770
        6S is a voltage measurement (22.2 volts nominal), ampage is a different thing entirely, and will depend on Rpm and prop size, spin an X427 at low RPM on 6s and a 30A ESC will be plenty, try spinning an X467 at high RPMs on 6S and you will blow a 400A ESC.
        • jim82
          • Jan 2013
          • 1358
          Leopard/Tp 4074 or 4082 in the 1600kv range should get you in the 70's no problem with the right prop.
          • HTVboats
            • Jun 2011
            • 936
            I have a KEP's P rigger with a 1415 1Y (2400kv) Castle and a Flycolor 150 that works well on 4S. Mid 60's in 6 lap trim. Similar size to the JAE33. Going to Q-6S with a TP 36X75 (3640) 5Y 1570KV would lower the amp draw and pull more prop. I would think 70mph would be attainable. A TP3650 (36X85mm) would have more watts and might stress the 150 esc. Many 40mm motors work but I like the 36mm for that size hydro. Have to try this one.
            Interesting idea with a limited size "econo' rigger that runs very respectable speeds.
            Mic
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • rol243
              • Apr 2017
              • 1038
              what prop do you run on this rigger set up Mic ? i have the same set up on my jae 21/fe but not sure on the H7 prop yet.
              • HTVboats
                • Jun 2011
                • 936
                I have run the ZippKits cut down 1450, H-7, H-10, OCT X642, N940, ABC 1816 & 1817. All ran well but I think our fastest 1/4 mile times were with the 1817 and next go to would be the 1450. Still a few more to try. This is with Castle 1415 1Y 2400kv.
                Mic
                Mic Halbrehder
                IMPBA 8656
                NAMBA 1414
                • jim82
                  • Jan 2013
                  • 1358
                  What size coupler fits 1415 4mm? Nvm found my answer 1/8
                    My own FE21 with Castle 1415/1Y runs best with a cupped H-7, it runs 12 second laps with max speeds on the oval in the high 70s on 4S. I haven’t tried low-lift ABC props but would expect them to perform even better.
                    BTW my 1415 has a 5mm shaft.
                    • raptor347
                      • Jul 2007
                      • 1177
                      So, rough calc: TP 3650-7D, 1815-17-45, 2x 6S 3000-3300 parallel, 150-180amp esc. 36K rpm. 78mph@15% slip.
                      Should be fun.
                      Brian "Snowman" Buaas
                      Team Castle Creations
                      NAMBA FE Chairman
                      • chevelledude
                        • Apr 2017
                        • 54
                        You have to work to get 1 6s in this hull.
                        • rol243
                          • Apr 2017
                          • 1038
                          you need to make the tub abit wider on the jae21/fe to fit a 6s lipo or buy the jae 33 which fits a 6s easy.
                          • raptor347
                            • Jul 2007
                            • 1177
                            You could probably go 6S4000's but the run time won't be fantastic.
                            NAMBA FE Chairman
                              How about two 3S/5000s in series?
