Smarty Pants
  • Ub Hauled
    • 3051
    Smarty Pants
    Guys, this is what is left from an attempt to check if a prop is balanced on a Dremel...
    yes... I went there... don't try this at home.
    I placed the prop on the shaft, the shaft on the Dremel (perfect fit BTW), and went to
    town on the "throttle"... there was a slight vibration on the beginning and it got
    worst, and worst, and worst... then the prop SHOT out of the shaft and into my back yard
    somewhere (lost) after ricocheting of a tree branch... all I heard was "kahpeeng", kling, kling... and no more prop. It gets worst
    Thinking this would not be a big deal I had no safety precautions nor gear, I could have had some serious "prop in the eye problem"... seriously, avoid this silly attempt to check if the prop is balanced, find a safer way... I know I will, don't wanna lose another prop (or an eye).
  • Spot Me 2
    • 770
    Your lucky!! You could have been hurt or killed!
    MMGMMarine
    RobertsonRacing
    • Ub Hauled
      • 3051
      Living and learning...
      I guess I was a little lucky...
      lesson learned.
      • Xzessperated
        • Apr 2008
        • 3063
        Thinking this would not be a big deal I had no safety precautions nor gear, I could have had some serious prop in the eye problem... seriously, avoid this silly attempt to check if the prop is balanced, find a safer way... I know I will, don't wanna lose another prop (or an eye.
        I am pleased you were not hurt. Maybe we could add a "Things not to do" section to the computer program Jan.
        Good luck at your SAW event this weekend.
        • Ub Hauled
          • 3051
          That's a good idea Paddy... it was a silly attempt to do something new... I will wear goggles next time
          • Jimmy Sterling
            • Apr 2008
            • 417
            That prop must have been a fair way out of balance to do that
            Come to the FASST side
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              UB, thank you for your honesty in relating your error.....many others would not. The dremel fixing method and trueness I would not trust as it would increase any out of balance problems.
              Glad you are OK
              Douggie
              • teach
                • 509
                Now that we know you are not hurt, is it wrong to giggle......just a little.....on the inside?
                Bad part is I thought about doing that too.
                • Ub Hauled
                  • 3051
                  Oh, I am laughing at it, that's all I can do, right?!
                  Sterlo, I think the prop was very close to being in balance, I think the problem
                  started with the 2 little cones (plastic) that probably were not balanced well and then
                  they un-lodged from the prop and then the prop got outta axis... that's when things went array... quick.
                  • Steven Vaccaro
                    Administrator
                    • 8934
                    Luckily everything turned out great!
                    When I was new at repairing jewelry, I did a similar thing. Someone had us repair a ring that had a top design that spun on a set of micro bearings. I was using a high pressure steam machine to remove the dirt and the top was spinning rather quickly and sounded cool(I can still hear it today, sounded like a jet winding up!). So I tried it a few more times, UNTIL I hit the rpm limit for the bearings. The ring blew apart with the bearings and ended up all over the place. LOL Needless to say my father was a tad bit upset with me.
                    Steven Vaccaro
                    • Ub Hauled
                      • 3051
                      You guys have to agree that it was a good idea on paper... high RPM... a balanced prop...
                      a shaft that fits perfectly... the cones that are off balance plastic... oh wait, that is the mistake.
                      • egneg
                        • 4759
                        Might work with the proper size drill rod, prop dog, and collar.
                        IMPBA 20481S D-12
                        • Xzessperated
                          • Apr 2008
                          • 3063
                          LOL.
                          It always makes me smile that first we have to balance the balancer before we balance a prop. What ever happened to quality control? Maybe they could make a RTU (ready to use) balancer. I would not mind paying a little extra for that.
                          • Xzessperated
                            • Apr 2008
                            • 3063
                            Chuck, now he needs a prop dog to go find the missing prop.
                            I guess only Andym will get that joke.
                            • Ub Hauled
                              • 3051
                              LOL
                              that is funny... I do need a prop dog to find my prop again...
                              that is pretty good Paddy...
                              Speaking of which, have you hit 100 yet (on water that is)?
