FYI, TP Motor news......Changes to face plate!
  • Steven Vaccaro
    Administrator
    • 8932
    Check out the picture.
    The Gold faceplate(on the left) is the new model called v1.
    v1 is the new version.
    v1 is using 4mm screws in a 4 bolt pattern.
    v1 is 40.0mm which means that water jackets will also change.
    The Black faceplate(on the right) is the old model called v2.
    v2 is the old version.
    v2 uses 3mm in a 6 bolt hole pattern.
    v2 is approx 39.7mm
    Steven Vaccaro
  • Keagan-Z06
    • Mar 2016
    • 970
    Will this be standard across the lineup? I just ordered some TP4050s from you, are there any other changes?
    • Steven Vaccaro
      Administrator
      • 8932
      Im not sure. We thought just the cm motors were changing. Ill know more soon.
      Steven Vaccaro
      • Keagan-Z06
        • Mar 2016
        • 970
        Crap! Well hopefully good things to come. These will be my first TP's and I'm stoked.
        • Peter A
          • 1622
          That will need changes to mounts also to fit the new bolt size (obviously!). Could be a tad annoying if upgrading, new motor, buy new mount parts also.
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            The bolt hole spacing is still the same [25mm] - worst case scenario you might have to hog out the holes originally configured for 3mm screws.
            • RaceMechaniX
              • 3024
              The other main difference is the V1 has a three piece can (center body and two end caps), the V2 has a two piece assembly (can and front plate as one, separate end bell).
              Just a word of recommendation, if you plan on supporting the wire end of the motor either will work. If you are only supporting at the collet end, opt for the older design V2 which has a one piece front end bell and motor can. The bolted three piece assembly will be more likely to loosen over time and bouncing.
              TG
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
              • properchopper
                • 7708
                The 4mm Gold motor versions were specifically configured for the car RC market which requested that feature - the 4070's are still available with the 3mm spacing, as should (I'll have confirmation tomorrow) the other motors. I have a 3mm mounting bolt 4070 and it's a heavy beast that, consequently, motivated me to go fairly overboard making sure it wouldn't break loose while at the ballet :
                • Peter A
                  • 1622
                  Little bit trickier with the water cooled front mount plates. Drilling out the holes is no problem but the heads won't fit. Not the end of the world, a longer screw with a flat washer will probably suffice. I don't use the cooling on these but perhaps a non cooled plate that will accommodate the new design, or make your own. I did see a post a while back on facebook of a new prototype mount being developed, and that looked like a good one. How's that coming along Steven?
                  • properchopper
                    • 7708
                    Turn the water cooled plate around and you'll have a flush surface for the 4mm heads- I do that when I use one, coupled with the fact that I use permanent studs in my race motors to make between-heat replacing faster using nuts which are easier/faster to deal with (and they clear and seat on the flush surface)
                    • zooma
                      Local club FE racer
                      • May 2014
                      • 653
                      [ATTACH=CONFIG]148227[/ATTACH]
                      Studs are a great idea, thanks. Do you just use thread locker?
                      Ron - The Villages, FL
                      • properchopper
                        • 7708
                        Loctite Red
                        • zooma
                          Local club FE racer
                          • May 2014
                          • 653
                          Loctite Red
                          OK. I'll have to try that.
                          • grsboats
                            • 1011
                            Yes I've been using studs with red loctite with no issues....just care about screwing them to avoid inside damage.Gill
                            GO FAST AND TURN RIGHT !
                            www.grsboats.com.br
                              What length stud do you use or does it vary?
                              What tool do you use to tighten the nut when motor is in tight areas?
                              This is attractive for a hull I can use for both p-limited and p mono. Just add a tail ring support.
