I just bought a Genesis cat and will be running the stock motor for now with a seaking 180 ESC.. I'm switching to a 3/16 drive and I have both 4s and 6s 5000MAH 50c min packs for it. My question is what is a good setting for the strut height, also the strut angle number would help too. eventually I would like to go with a bigger motor but for now this is where I am.
Genesis setup questions
Should have mentioned also if you are using the stock 2075 SSS motor go with 4s and I had good luck with a x443 prop. Battery placement is critical. Move them as far back as you can to get the front up to the point of blow over. Boat works best in light wind and chop on the water. Hates flat dead calm water too much drag on hull. I got 43 mph with that set up.
Again thank you for this info, I could have spent days getting to the point where I had a decent setup to run with... I have 2 weeks to get this boat into the water because of a jass festival at the local park we run at but I would like my first electric boat to run good out of the box. If you have any other tips I might be able to use please feel free to share..
Sorry, just saw your post, I have pretty good experience with the Genesis. The hull reacts different to motor, kv, cells, and prop setup.Originally posted by slider46 View PostI just bought a Genesis cat and will be running the stock motor for now with a seaking 180 ESC.. I'm switching to a 3/16 drive and I have both 4s and 6s 5000MAH 50c min packs for it. My question is what is a good setting for the strut height, also the strut angle number would help too. eventually I would like to go with a bigger motor but for now this is where I am.
On a side note, if you run the SeaKing/Turnigy 180a ESC. MAKE SURE to calibrate the throttle at least 1 time before each boating session, or you will only be running the boat at 80% throttle. To calibrate, pull throttle to 100%, turn on ESC, hear 2 beeps, release throttle, 1 long beep, then it should finish arming. Make sure to do this or you boat will run slower than it should. I really wished Hobbywing would make you calibrate your throttle every time you arm it, like Aquacraft does.
For strut angle, I would start at 2-3mm negative from neutral. Do a few laps and see how the boat is riding. Then adjust the strut up so at -1mm negative to neutral. Do a few more laps. Keep doing this until the boat either rides too high or too easy to flip. Then back it down 1mm.
For both my Genesis, they run neutral on the strut, it's completely flush with the strut mount. However, I run an airdam to prevent blow over at speed. If I didn't run the airdam, I would have to run the strut at about 2mm negative and lose about 5 mph.
If you run your Genesis at above 50mph, you MUST reinforce the hull and canopy. It will eventually crack after a few flips. You don't have to go fancy with carbon fiber, a layer or two off fiberglass cloth and resin will do just fine.
Below are some videos with my Genesis in either 4S and 6S for reference.
Here is my Genesis on 6S on-board:
Another on 6S, sorry for the talking:
On 4S, again sorry for the talking:
Sure, it's just the carbon airdam for the UL-1 on Kintec Racing website.
Just cut it to fit the width of the Genesis, and use some outdoor double sided tape to apply it, about 2.5 inches from the front of the boat.
I have run in over a year in salt water and it hasn't come off. It has really helped the blow over issue for me. Also, I run my batteries in the sponsons, and my ESC as far front as I can.
Sure, check out post #14 of this thread link below, I post a couple of pics of my airdam for the Genesis. Also, this is a good thread to read about the benefits/issues with airdams.
http://forums.offshoreelectrics.com/...ghlight=airdam
