Originally posted by slider46
View Post
Genesis setup questions
Are you using the program box(preferred, easiest way!)? If so there are videos on YouTube, etc.Originally posted by dbonomi View PostCan't figure out how to set the timing on my 180A Seaking esc. Using a tp power 4060...1950kv motor, 3/16 shaft, Octura m445 prop and run on 6s...Does anyone have any suggestions
If using your transmitter like I did recently, it takes a few times to do it but the follow the "beeps" and it will work.
Thanks Jim. I was going to set it at 7 degrees but I'll take your advice and re-progam it as you suggested. By the way, I'm also running a hydro with a 180 seaking esc with a Leopard x 3650 3150kv motor. I'm using 1...3s or 4s...5000mah battery and a cnc 438 prop. How would you set the esc timing with this set up?
Runningman here are some pictures of my setup for you
